2.5 ton Toyota (Sawed off) - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 07-15-2011, 06:49 PM   #26 (permalink)
Member # 134262
I like it
it will throw of all the rednecks
can go from the monkey to jungle jim
samurai4u is offline   Reply With Quote
Old 07-15-2011, 07:05 PM   #27 (permalink)
----MSi----
repooc's Avatar
Member # 104330
repooc is offline   Reply With Quote
Old 07-18-2011, 03:08 PM   #28 (permalink)
Member # 135242
KEEP THE STINGER!!! I've seen them "hillbillys" stick them there mega trucks in pits so hard they roll'em over nose first. I dont know if they know that that stinger thing is just for that!!!
82 Yota, 39.5 cut boggers, doubler, full hydro, exo, 22r, under 4grand in the whole build!
KingofChilli82 is offline   Reply With Quote
Old 07-19-2011, 07:47 PM   #29 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Yay paint.
Old 07-20-2011, 09:13 AM   #30 (permalink)
Member # 128286
Tell Jason to stop doodling on the damn camaro
daryl is offline   Reply With Quote
Old 07-20-2011, 10:09 AM   #31 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Lol
Na that was my boy airbrushing.
Old 07-20-2011, 07:55 PM   #32 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Old 07-30-2011, 05:09 PM   #33 (permalink)
Member # 147824
i like it , if you decide to sale it ,706 564 5454
lovett is offline   Reply With Quote
Old 08-01-2011, 06:04 AM   #34 (permalink)
----MSi----
repooc's Avatar
Member # 104330
I got the low pro airfilter on and I still needed room. So I made some by cutting up the hood of the camaro. I also install my new coilover springs and mounted my ele fuel pump.
Old 08-02-2011, 08:03 AM   #35 (permalink)
----MSi----
repooc's Avatar
Member # 104330
I hate fiberglassing but it will look good when I'm done.
Old 08-12-2011, 08:25 AM   #36 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Mounted my switch box.
Old 08-12-2011, 08:50 AM   #37 (permalink)
Member # 109601
i'm just asking to ask but when you glassed your hood did you use any material or matting? it "looks" like it is just resin? if you used material...cool...carry on don't mind me. but if you just used a lot of resin, then it will brake loose and or have a crack around the seam. resin by itself dries and becomes brittle the material with resin in it is what makes a strong hold on the seams. aslo using a little Dura-glass will beef it up and rage gold body filler to top it off and you will be set. (i do a lot of glass work so i was just trying to help out). when i glass i get my piece of material soaked threw and threw i gently use a bondo yellow paddle and run down the piece to remove the excess resin, and also overlap all the joints.
all in all this is really nice build and CAN'T wait to see it tearing up the mud!!
nvrsatisfied is offline   Reply With Quote
Old 08-12-2011, 09:11 AM   #38 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Trust me I understand why you ask the question. Lol. Yes I used some of the heavy woven mat and layed the resin on thick so I could sand it down smooth. If you look real close you can see the outline of one of the pieces of mat at the front of the scoop. So you think I should some dura-glass and rage? I was going to sane, glass again, sand and use filler. How much easier and or better are Dura-glass and rage? Thanks for the help.
Old 08-12-2011, 03:05 PM   #39 (permalink)
Member # 173265
Badass build man. I was looking at those painless switch panels for my build but the price forced me to look elsewhere. I found 12voltguy and his kickass custom switch panels are badass and easy on the pocketbook for what your getting. Just letting you know for next time around! Keep on workin!
1981 K20 pirate4x4.com/forum/showthread.php?t=996844
chevy_phil is offline   Reply With Quote
Old 08-12-2011, 05:31 PM   #40 (permalink)
Member # 172687
Send a message via AIM to joeydodgemuddin
aweet build love the yoda and big tires any advice you can give a kid on faborcation i just started welding school and be playing around with it in step dads race shop
joeydodgemuddin is offline   Reply With Quote
Old 08-12-2011, 08:56 PM   #41 (permalink)
Member # 109601
I know its not for show... But if you knock it down some to the material, duraglass is a fiberglass type filler, it has fiberglass hairs mixed in it and works just like a bondo as far as mixing goes, but also a little tougher and gives a minimal flex. Once it is dry it has a more rugged texture, so a body filler of sort will help fill in the pin holes and crevesus. I use rage because it knocks off easier when block sanding, if you cant get rage mix a laqour thinner with bondo and it will thin it out causing it to knock off easier and lay thinner, it can also setup quiker so experiment away... But overall if you leave too much resin it will break eventully break loose and have a crack around the seam.... Like I said its not a show piece, but incase your picky like me on YOUR work, then there you go....
I dig the project either way!!! Looks great and keep up the work!
Old 08-15-2011, 09:13 AM   #42 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Awesome thanks for the help. where do you get your rage and Dura-glass?
Old 08-15-2011, 09:16 AM   #43 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Yeah, Never be afraid to try anything as long as you have considered safety first. Build things you like, don't follow the crowd.
Wish I went to welding school lol.
Old 08-15-2011, 09:19 AM   #44 (permalink)
----MSi----
repooc's Avatar
Member # 104330
Yeah I know about the 12voltguy and like his stuff just been running Painless and liked the setup. I am planning on building my own setup one of these days when I get time lol.
Old 08-15-2011, 12:21 PM   #45 (permalink)
Member # 109601
my local o'reilly's carry the Duraglass and i can get Rage Gold threw either work or from my buddies, they order it up sometimes, they run a body shop. might check if you have a local paint shop or body shop they might carry it or something similiar.
Old 08-15-2011, 04:02 PM   #46 (permalink)
GZ
GZ's Avatar
Member # 176008
When are we wheeling together! Get this thing done! Good seeing you at redneckfest! Lol
03' Z & 2 Zuks.
GZ is offline   Reply With Quote
Old 08-16-2011, 12:21 PM   #47 (permalink)
----MSi----
repooc's Avatar
Member # 104330
I am going slow and steady. lol
Old 08-16-2011, 07:57 PM   #48 (permalink)
redneckryder84's Avatar
Member # 57010
are you running a front and rear sway bar or just one? got any pics of how you mounted it in realtionsship to the coilover and links?
redneckryder84 is offline   Reply With Quote
Old 08-16-2011, 08:05 PM   #49 (permalink)
Member # 172687
Thumbs up
thanks gong to start building my dodge to send down to florida hopefully my next yr to bunnell mud bogs and a redneck yott club event i miss fl so much nice build keep going
Old 08-16-2011, 08:26 PM   #50 (permalink)
Member # 195268
When you get it done you planning on takin it to bricks the run through the slough?
67tundra is offline   Reply With Quote
