full manual valve body - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > General Tech > Mud
Old 07-13-2011, 05:58 PM   #1 (permalink)
loweredf1's Avatar
Member # 133951
just wondering if anyone is runnng a reverse pattern full manual valve body? i have a built c6 setup with tci rpfmvb and cant decide if it would be ok to run in the mud truck if i get bogged down and need to down shift it probably wouldnt be good to slam back to 1st.
(witty dozer) buggy, 127"WB, F/R steering rockwells, 49" Iroks, 418w sbf on pane
build:http://www.pirate4x4.com/forum/showt...ht=buggy+build
76 f100 14.9x24r1's, rockwells, 460bbf, 435, 205 built beat and sold.
2011 f350 cc srw 6" lift 37's on 22's
loweredf1 is offline   Reply With Quote
Old 07-13-2011, 07:12 PM   #2 (permalink)
Member # 152538
i would run a reverse pattern full manual valve body. Just run it with a gated style shifter (art Carr) for the trans you have and make sure it is for a reverse pattern. You will dig it!
Lowgear is offline   Reply With Quote
Old 07-13-2011, 07:25 PM   #3 (permalink)
Member # 106427
I run one on my th400 and trans brake with the b&m pro ratchet. I beat it to death, and still going strong
later
jenks
jenks21 is offline   Reply With Quote
Old 07-13-2011, 10:20 PM   #4 (permalink)
Mopars 4 Life's Avatar
Member # 108404
i have ran them for years with a b&m prostick. the shifter has all the different gates so you can change if needed. Just be sure you use the safety lever when goin back to 1st, i accidentally pulled it in (or something lol) and hit neutral at WFO,,,,,not good lol I would still highly recommend the reverse pattern manual for mud.
"Yep, no sissy poser no use other than look good pansy crap on my truck!" Willyswanter
Mopars 4 Life is offline   Reply With Quote
Old 07-14-2011, 05:20 PM   #5 (permalink)
loweredf1's Avatar
Member # 133951
so you guys go 2nd back to 1st at wfo?
Old 07-15-2011, 10:00 AM   #6 (permalink)
Member # 108404
well sometimes i have had to lol , say you shift early and the mud is deeper than you thought, it bogs a little so id just rather go back to 1st and get the RPM back up lol Of course i have ran deep mud in 1st gear all the way and hold the son of a bitch right on the floor.
Old 07-21-2011, 06:32 PM   #7 (permalink)
Member # 9041
What's the advantage in your opinion to a reverse pattern Vs standard manual valve body?
Give it just a little more, you'll make it
mudtrux is offline   Reply With Quote
Old 07-22-2011, 03:36 PM   #8 (permalink)
Member # 37607
Send a message via Yahoo to YZEATER
my truck came with a reverse valve body. you don't need it to be reverse pattern, just full manual either way, whatever your preference is. just get a good gated shifter. i have a hurst quarter stick and it works awesome.
yes, i shift from WFO 1st to 2nd and and then back to first if it needs it.
truck in sig.
85 chevy d60/14b, locked, 383 - mud racer
'11 cummins sbcc, 6 speed : '95 zj : '95 ZJ 5"
YZEATER is offline   Reply With Quote
Old 07-22-2011, 03:47 PM   #9 (permalink)
Member # 108404
because you are shifting away from neutral, but like i said you still have the chance of hittin it if you go back to first (that depends on your shifter and your reactions at the time though lol)
also i guess i am more talking of mud racing than trail riding but i would still rather have the reverse pattern.
