hydro assist and ifs front end. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-01-2011, 10:16 PM   #1 (permalink)
Member # 44310
LOOKING FOR INFORMATION, OR A YES OR NO. CAN HYDRO ASSIST BE USED ON A IFS FRONT DIFFERENTIAL? THANKS IN ADVANCE. scaf
stcfoster is offline   Reply With Quote
Old 09-01-2011, 10:27 PM   #2 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
yes it can.
what kind of ifs are you trying to use?
what kind of steering are you trying to use?
Old 09-01-2011, 10:44 PM   #3 (permalink)
Member # 44310
Originally Posted by trkklr77 View Post
yes it can.
Haven't decided on make to use yet. Just looking for information on hydro assist being used on a stock (1988) IFS front end. Everything I've seen has been geared towards straight axle front ends.
Old 09-02-2011, 06:17 AM   #4 (permalink)
NorCal_Chris's Avatar
Member # 140551
the latest (i think) petersons mag has an f150 that they stuck hydro on. it uses a wayyyyy long double ended ram, and fits right in the middle.
http://www.4wheeloffroad.com/ultimat...t_4/index.html
adfasd
NorCal_Chris is offline   Reply With Quote
Old 09-02-2011, 08:21 AM   #5 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
why the hell would you do it to a stock ifs system?
if it was a race twin beam or a long A arm setup yeah fine, but you are going to wreck that ifs diff and shafts before you get tires big enough to need hydro ass.
Old 09-02-2011, 08:24 PM   #6 (permalink)
Member # 44310
Talked to a couple of manufacturers and the call is that no one makes a kit for an ifs front end. To bad. Not off road alot, but got little skinny grandpa arms.
88 toyota, true track front and back, high performance 22re, lectric fan, mile marker hydraulic winch (10,000lb) 6" lift, High volume pump to go with it. And gone thru from front to back, new bearings, tie rods, rebuilt the tranny replaced the interior, bucket seats, disc brakes on rear axle, and dun it all myself. Just trying to figure out what's next. scf
Old 09-02-2011, 08:57 PM   #7 (permalink)
skullfuckery
trkklr77's Avatar
Member # 29016
wtf do you need a "kit" for?
psc kit, with or with out new ported sttering box, some scrap plate .250", welder = toy ifs "kit"
out of that entire list there is only one thing is going to make any bit of a difference on how hard it is to steer, and you still didnt bother to say how big of a tire youre running.
Old 09-02-2011, 09:20 PM   #8 (permalink)
Member # 44310
running 33 inch tires right now. nothing extreme. I figure I can cobble something together, just a lot easier if you have an example to look at. Already have the drilled steering box. Did that when I replaced it. Just have to take the plugs out to use it. Guess Ill just have to crawl underneath and do some visualizing. (Also put some HID lights in it.)
Old 09-02-2011, 09:25 PM   #9 (permalink)
Member # 24558
The stock toyota power steering should easily be able
to handle 33's....
edit; what will wear out is the idler arm....
yota running gear[dual t's] 4.3 sammi body
39.5 stauns 4 linked f/r
fruitypie is offline   Reply With Quote
Old 09-02-2011, 09:36 PM   #10 (permalink)
You Dumb Bastard
keller's Avatar
Member # 34281
Send a message via Yahoo to keller
Pointless.
Shop build Thread
91 Tracker--38s--Doubler--Build Thread
05 CTD reg cab 6speed
emiller22207 is a huge pile of inhuman shit.
keller is offline   Reply With Quote
Old 09-02-2011, 09:48 PM   #11 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
gotta remember that steering bar is not very strong, they actually recalled them for breakage issues. i would think that adding a hydro assist to a stock toyota link steering system is a time bomb.
man-up, start drinking your carrot juice, do some curls (not the 12oz ones either), get them grampa arms back in shape. straight axle that truck, get crossover and highsteer, then start thinking hydro assist.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 09-02-2011, 10:59 PM   #12 (permalink)
"The" Bodie
TheRevolution's Avatar
Member # 197330
in my opinion if you are running big enough tires to even consider hydro assist, you shouldnt be running ifs anymore
Bangin' Rocks Revolution Style
TheRevolution is offline   Reply With Quote
Old 09-09-2011, 01:56 PM   #13 (permalink)
Member # 181990
I have 37" Boggers on my 92 Toyota, it's still IFS. Stock pump and box turns em just fine.
mudjunky13 is offline   Reply With Quote
Old 09-09-2011, 08:08 PM   #14 (permalink)
I See You
Provience's Avatar
Member # 138976
Agree!
honest solution, buy a larger diameter steering wheel. if you have skinny grandpa arms, hopfully you have a skinny grandpa gut, a bigger wheel will give you much better steering feel and preserve you stock steering components from the stress of the hydro assist
Provience is offline   Reply With Quote
