81 toyo runs but dies when let off gas pedal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-03-2011, 12:47 AM   #1 (permalink)
Member # 199465
My 81 toyo 22r only runs if i give it gas. I can drive it fine but will not idual. Checked all vac line and fuel line/filter fine and drained the tank and ignt checked. Also wont pass smog cause of egr value. But i have replaced it like i was told by the smog guy to do havent taken it back to get smog so dont know if it will pass cause of this problem. I cant take it there. Only idea was the carb any help would be great. thank u
honda183 is offline   Reply With Quote
Old 11-03-2011, 12:39 PM   #2 (permalink)
smogman's Avatar
Member # 151434
not enough info to help you. You need to do some basic testing first and give us the results. start it and try to keep it running while spraying carb cleaner in the intake. If it continues to run then you know its fuel. Could be the idle solenoid but like I said, you need to do some testing.
"Test Only Smog Check"
Sacramento, Roseville, Antelope, Citrus Height & Rocklin. "No Pass No Pay" Smog Check.
We smog jeeps, toyotas, samurai's, anything that needs a smog. We also do Diesel Smog Checks
smogman is offline   Reply With Quote
Old 11-03-2011, 01:54 PM   #3 (permalink)
SGT BAILEY's Avatar
Member # 162990
just raise the idle with the idle screw till your happy.
SGT BAILEY is offline   Reply With Quote
Old 11-03-2011, 01:54 PM   #4 (permalink)
Member # 199465
Thank u dont know a whole lot new to the 4x4 area aways raced bikes since i was little.I tryed that and it did nothing is there a way to check idle solenoid or any other ideas want to fix my self so i can learn. Thank u
Old 11-03-2011, 01:58 PM   #5 (permalink)
Member # 199465
i was told that the idle screw is sealed and cant be messed with from factory. idk but was told that so i never looked at it
Old 11-03-2011, 02:02 PM   #6 (permalink)
Member # 199465
nevermind that last 1 stupid answer ment the mixer scwer cant be messed with
Old 11-05-2011, 02:05 PM   #7 (permalink)
smogman's Avatar
Member # 151434
If you raise the idle with the idle screw it's going to diesel.
check to see if you can keep it running with carb cleaner. if you can you either have a huge vacuum leak or the idle cut solenoid might not be working. I can only shoot you in the right direction, I can not fix it for you.
Old 11-05-2011, 02:22 PM   #8 (permalink)
058hamer's Avatar
Member # 24417
When is the last time it had a tune up?
058hamer is offline   Reply With Quote
Old 11-06-2011, 11:58 PM   #9 (permalink)
Member # 199465
thank u guys for the help got it going it was the vac line that connects to the tvsv it was blocked. when i pulled it off some crap and a tiny bit of fule came out. nother stupied ? y was there a tiny bit of fule in those lines??? just want to know thank u for the help
