38's and TTB - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-24-2011, 09:31 AM   #1 (permalink)
knightkrawler's Avatar
Member # 179963
38's and TTB
Anyone ever have a three inch body kit and a six inch suspention kit on a F150 with a Dana 44 ttb front end running 38's? I have been told and read that the ttb will not stand it but saw a truck about a year ago running that set up I just never found the driver. I hear you can swap parts off an F250's Dana 50(?) ttb knuckles and hub(?) Figure the flameage will be on so I asked it here in the newb section.
90 F150 SC SB 5.0 AOD BW1356 33X12.5 MTR's
'Resistance to tyrants is obedience to God." Jefferson
knightkrawler is offline   Reply With Quote
Old 11-24-2011, 04:33 PM   #2 (permalink)
Member # 198963
Had a buddy with a bronco TTB running 38 tsl. He was always breaking axles I mean everytime we went out. Another buddy swaped out his TTB for a solid Dana 44 and runs 38 boggers with no problems. He does have chrom moly everything though.
k5muddbuggy is offline   Reply With Quote
Old 11-25-2011, 04:49 AM   #3 (permalink)
Member # 179963
Well that settles it then time to do an sas since I got a solid Dana 44.
Thanks.
Old 11-25-2011, 05:01 AM   #4 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
Send a message via Yahoo to fatboyf150
Been running 38.5's since 99 on my 95 and have never had a problem with teh front other then alignment. I have busted teh 8.8 twice though.
P.s. Don't try to do this on the rocks.
What happens in the Cooking Forum, stays in the Cooking Forum.
www.facebook.com/kenneth.rivenbark
fatboyf150 is online now   Reply With Quote
Old 11-25-2011, 05:09 AM   #5 (permalink)
247pia's Avatar
Member # 174055
Thanks.
If you just don't have anything to do that's fine but you are just wasting your time swapping in the straight axle that is marginally stronger than the ttb.
Save up for a 60 and don't waste your money on a straight 44 swap. You might find that you don't even break the ttb.
247pia is offline   Reply With Quote
Old 11-25-2011, 06:37 AM   #6 (permalink)
Member # 106806
X2 the 60.
my build: [url]http://ovo.ca/forums/showthread.php?t=867[/url]
Diesel_Dirk is offline   Reply With Quote
Old 11-25-2011, 06:42 PM   #7 (permalink)
Member # 179963
Dang I know I could not rock crawl just use it as a trail ride/hunting truck/daily driver also what all have you used to achive that clearance?
That is adding more fuel to the original ideal.
Originally Posted by Diesel_Dirk View Post
X2 the 60.
Would love a 60 but I'm trying afford it in the next year and a half not three.
Old 11-25-2011, 06:54 PM   #8 (permalink)
Member # 120067
Maybe you can give bobby a call at solo. They run 37s and his ttb holds up through baja
http://solomotorsports.com/index.php...1-solo-class-6
TPIfj40 is offline   Reply With Quote
Old 11-25-2011, 06:56 PM   #9 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
At one time it was just a 1" daystar leveling spacer for the front, a 3" body lift and trimming the front bumper.
Old 11-25-2011, 10:12 PM   #10 (permalink)
Member # 179963
Wow figured I would need a six inch suspention kit to fit them and a three inch body lift
Old 11-26-2011, 04:51 AM   #11 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
You won't need all that. If you look at the spacing between the fender and tire of each pics I posted, you will see the difference. The top is with the 6"/3" lift and the bottem is with the level/3". I did have the front and rear sway bars installed until I got the 6" lift. I think it kinda saved my fenders, plus I drove the truck daily, even on fire calls.
Old 11-27-2011, 02:14 PM   #12 (permalink)
Seabass's Avatar
Member # 49159
Maybe swapping dana50 ttb stuff would work for you. Plentifull in junkyards around here and cheap.
THINGS I NEED:92-93 Ford srw dana 60 knuckles. Everything balljoints out.
W56-C toyota trans
Seabass is offline   Reply With Quote
Old 11-28-2011, 05:00 AM   #13 (permalink)
Member # 179963
Do you ever rub when you hit a deep rut or start a steep climb? Looks like you lost ten inches of travel on the two photos
Yes what I started off wondering...
Old 11-28-2011, 06:43 AM   #14 (permalink)
Seabass's Avatar
Member # 49159
There's a couple builds on here with that front end. They were both koh style rigs. I wanna say search for juggy cant remember if that was the screen name or build name. The one I remember was on a wrangler
W56-C toyota trans
Old 11-28-2011, 07:14 AM   #15 (permalink)
Tonka Truck Driver
fatboyf150's Avatar
Member # 115381
I didn't lose, I gained. I had the bumpstops extended down to where I wasn't scrubing to bad. You will scrub the radius arm like crazy.
Old 11-28-2011, 07:25 AM   #16 (permalink)
KyleQ's Avatar
Member # 83837
That is a tall order for the TTB. I run a power-lok and with 32" BFG's and 34" LTB's I broke the front end every single time I went out with it. Upgrading the Spicer joints and full circle snap rings helped, but I moved rom u-joint failure to catastrophic shaft failure.
At least chuck a D44 under it - you can make it live with 38's and an open diff.
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers
Bronco Build Thread
KyleQ is offline   Reply With Quote
Old 11-28-2011, 08:09 AM   #17 (permalink)
Member # 179963
I dont plan on locking it or adding a posi to it to just keep it open in the front as I said before this will be a light trail truck/hunting truck/daily driver for easy trails with my family in tow my daughter is already hooked on wheeling, my wife has lost her gusto since we got married, started paying bills and had kids and I want to rekindle the fun we used to have.
Now that said I'm wanting to build a second 87-96 with an extended cab to fit two childs seats in and be built for harder trails so I will look for a 1 ton with a solid axle from the factory or 3/4 ton since I have read that the swap for a 3/4 ton is easy and pretty much a drop in place ordeal...
Old 11-28-2011, 02:00 PM   #18 (permalink)
Member # 204274
I have to ask....
Why do you want to run 38's so bad?
You'd be better off, still have plenty of clearance and be less prone to breaking stuff with 35" or 36" tires....IMO
Raleigh1 is offline   Reply With Quote
Old 11-28-2011, 06:17 PM   #19 (permalink)
Mall Crawler's Avatar
Member # 161111
Hell My buddies cuzzin ran 44's on a ttb with a 6 in. body lift. I'd say go for it! Dumb muthafucka just run 36's
1986 chevy 460 efi AOD 54 boggers no lift
Mall Crawler is offline   Reply With Quote
Old 11-28-2011, 06:31 PM   #20 (permalink)
Super Willie
Tech Tim's Avatar
Member # 19067
X3 on the D60.
They are fairly cheap on Craigslist, anywhere from $700 to $1500.00 depending on ball joint or kingpin and the condition of said axle. You can spend that much easy trying to keep a D44 alive with 38s.
Tim Lund
Yeah, I wear a Kilt... what you're not man enough?!
Want beadlocks? Allied Beadlocks.... Best designed and best priced aluminum beadlock on the market!
Got 40 SPLINE? Time for you to get 40 spline too! 40 spline hubs, spindles, outer stub shafts, 40 spline 14 bolt & Dana 60 Air Lockers
http://www.wildwestfab.com.... WILD WEST OFF ROAD 360-264-5363
Tech Tim is offline   Reply With Quote
Old 11-29-2011, 05:16 AM   #21 (permalink)
Member # 179963
Originally Posted by Raleigh1 View Post
I have to ask....
Saw it done on a truck and I liked it I never found the owner of the truck and only saw it once but it looked pretty sweet and I wanted to find out if it was a mall crawler actual trail truck. Hence me starting this thread seeing if anyone has ran a ttb and 38's....
Yes I could run 35's and I do plan running them on my 05 F250 but I want something a big larger on my truck since I figure I'm paying for it I might as well put what I want under my truck.
Old 11-29-2011, 05:31 AM   #22 (permalink)
Resident Beekeeper
CJesse7's Avatar
Member # 36707
Send a message via AIM to CJesse7 Send a message via Yahoo to CJesse7
x4 on the D60
do it right the first time, and in the long run you will be money a head.
A government big enough to give you everything you want, is a government big enough to take everything you have.
My Reverse Flow BBQ Pit Build
http://www.pirate4x4.com/forum/gener...pic-heavy.html
CJesse7 is offline   Reply With Quote
Old 11-29-2011, 10:30 AM   #23 (permalink)
Member # 179963
Originally Posted by CJesse7 View Post
x4 on the D60
I understand the reason for going to the D60 and if I could I would but money is tight I'm not seeing awhole lot of trail action and want to build a lifted truck cheap then go buy a second truck to do a proper build on.
Saddly the economy has taken its toll on me just like many other Americans but I'm not giving up on my hobby just trying to do it as cheap as possible, if I did a sas I would have to buy more tools, welder, have more shop space, and take money off the table from my family. If I did a D50 or D60 or hybrid 9inch/D60 I would not beable to do it in the time I want to have it done in.
Now if you want to finance this build by all means pay me but not everyone has the luxury or ability to build what they want right away so some of us take small steps.
Old 11-29-2011, 04:59 PM   #24 (permalink)
247pia's Avatar
Member # 174055
Leave the ttb in then.
Old 11-29-2011, 06:43 PM   #25 (permalink)
Jackstand wheeler
Redneck92's Avatar
Member # 192976
My buddy actually had this exact set up and for street it is fine, he never realy wheeled it much. I'd say just stick with it till you have the money for a 60, a 44 would just be a waste of time and money. A sas on the ttb isn't that bad depending on your mech skills.
86 4Runner "The Turtle" - 22RE 5spd, Dana 60 14 Bolt SAS on jackstands
02 Tacoma - 3.4 5 spd DD
Carolina Trailblazers
Redneck92 is offline   Reply With Quote
