im wanting to throw two 4k winches on my toyota ( front & rear)... i am aware ill end up having to snatch block everytime but just curious if im crazy?
Just buy the right sized winch the first time, 8k is pretty much the accepted minimum for anything bigger than a side by side for a reason. You'll end up doing a bunch more work and spending more time on every recovery, get tired of it and just upgrade later anyway, why not do it right from the start?
You're not crazy, just ignorant of how things work. You should always go at least two times a vehicle's weight when getting a winch. Sure, smaller winches are cheaper, and they might pull you out of some spots, but the components are not made for that sort of weight and will fail very quickly. The cable alone is so small on those winches that I wouldn't want to be anywhere around you if you were going to use it to pull out a Toyota. You're talking some serious lacerations and possibly killing someone if that cable breaks.
Do yourself, and everyone else around you a favor and get an 8000# winch and be done with it. You can pick them up pretty cheap now and a lot of companies make very good budget winches.
Youve gotta think what you will be using the winch for(stuck in mud or rocks, winching up a hill, winching yourself back over from a flop, winching friends, etc.) Alot of toys wiegh in at or over 4k. Then add in the resistance of whatever your pulling over or thru. General wisdom says buy a winch rated for 2x the vehicle wieght. And even at that you may want a snatch at times. Also you need to realize that the winch is rated at 4k lbs for the first wrap on the drum. More wraps=less power. And as with anything else, using a winch at or above its rated capacity will wear it out quickly. Smittybuilt winches are about 300 for an 8k. The badlands winches are around 200 for an 8k. There are 20% codes you can always use. Theres plenty of other winches for around $300. Its better to have the right equipment in a bad situation. If you can afford 2x4000lb winches you can afford 1x8000 winch. If you REALLY need to pull from the rear and have no other option you can run the winch under the truck. Or set it up on a reciever and wire up front and rear.
I have a Sams club "Champion" winch $300.00 on my TJ and have done some hard long pulls on it. Its slow but always drags me out. I have been running it for 4 years now without any failures or issues. I wheel in the rocks, no mud. As stated above, different environments require different equipment. Figure out where you wheel, and buy the right shit to get you home.
just think about this, a 2000lb winch barely sucks down my friends toyota leaf spring suspension, dont think a 4k would be good for more than a little 2 inch tug to get you moving in certain scenarios.
Put a pulley on the axle and run the cable back to the frame so it doubles its line pull strength Its basicaly running a snatch block on the suckdown winch.
have a 8000 on my 4 runner and has worked great. got me and other trucks out of some nasty shit.
