I'm installing a Spartan locker in my GM front Dana 60 with stock 4.56 gears/carrier. Will I have to slide an axle out, or will it fit in without axle removal?
You will have to remove both axles, because you will be replacing the internals of the carrier. I also don't see why you wouldnt just go ahead and remove the carrier from the housing and do it on the bench.
I had, I had just replaced the needle bearings inside the spindle a month ago.
