I currently have a 1987 Chevy 3/4 ton with a TH400/Np208 combination, The Transfer Case has some Internal Issues that Assuming is some Shift/Range fork issue, It doesnt like to leave 2hi and always seems like its in between etc.. Ive found a Gentleman locally that has a th400/Np205 with the Correct Round pattern Adapter out of a 86-87 1 Ton. Im fairly certain that the Adapter Case is gonna be Good, Im unsure about the Transmission Output shaft, I know they made a couple different variations Short/Long etc. Should the 2 be the same? I havent removed my case yet to determine which one i have and His is bolted together so he is unsure also. Just Curious..?
Thanks in Advance for Any and All Help.
Also his Case has the Slip Joint Rear Output, If that makes a Difference.
Steven
Under Suggestion i moved this too the Noob Section, Obviously my Question was too Dumbed down for the Chevy Section. LOL
Steven
