Search function and google used. Trying to find out what year model trucks they came in. Gotta make a grocery list and start calling yards/craigslist dance.
The NP203 transfer case was used by Dodge 1974-1979, Ford from 1974 to 1979 and Chevrolet and GMC from 1973 to 1979.
New Process Model 205 Parts List Part-Time Transfer Case Dodge 1969-1993 / Ford 1973-1979 / GMC 1967-1991
GM NP205 Transfer Case
General Motors Chevrolet has a racetrack (circle eight) pattern in the model years 1971 through 1985 with 8-bolt circle pattern. Later model GM NP205 units were supplied with 6-bolt circle pattern.
Ford New Process 205 Transfer Case
The Ford NP205 transfer case has a 6 bolt circular bolt pattern. The drop to the front differential is on the driver side; The Ford NP205 has a 31 Spline female input, and a 32 Spline output. Front output is also 32 Splines.
Dodge NP205 Transfer Case
The Dodge NP205 transfer cases were manufactured with 8 bolt pattern similar to the Chevrolet, in later years Dodge utilized 6 bolt patters, most units were supplied with a 23 spline male input and require a shaft coupler to connect to the transmission output shaft. Drops to the front differential are located on the passenger side, 29 spline units were used behind the 5-speed Getrag manual transmission in the diesel applications.
In case someone stumbles on this in a future search, some of the Dodge information is incorrect.
The NP203 was used in Ramchargers and Traildusters from '73-'79 but in trucks from '74-'79. All pickups in '74 and prior use a divorced case, the NP205 from '70/'71-'74 on ALL trucks.
The mated NP205 was used from '80 to '93 on 3/4 and 1 ton trucks that were equipped with the Dana 60 front axle only. All D44 equipped models used the NP208 from '80-'87 and the NP241 from '88-'93.
All Dodge mated NP205s use the typical 6 bolt pattern though some people for some odd reason seem to think that the adaptor is not part of the transfer case so that tends to confuse the issue. There have been a few Dodge trucks in the "full time era" that were equipped with the NP205 but these were usually W450 heavy ambulance or fire trucks, were not regular production and not something you will run into very often.
Thanks, that's exactly what I was digging for. I'm thinking these cases are gonna be harder to run by in decent shape than I thought.
