Member # 46308
difference between a kingpin dodge dana 60 and a chevy 60
I have the oppertunity to pick up a set of dodge dana 60's for my blazer cheap. Front is kingpin, has the internal hubs like the gm, and has 4:10's. Is there any difference between the 2? a friend told me just the yokes are different. everything inside is the same as the gm. Is that true?
Bangin Bible Holla |
Banned
Member # 202428
IIRC the the spring perches are slightly different widths and although the stub shafts are the same the inners are different depending on application. I think the SRW Dodge is 67" & the SRW Gm 69"?
Member # 18614
The dodge is narrower by a little bit. The dodge has a 2.5 wide spring perch and smaller leaf spring studs with a different top plate. the dodge the parch width is slightly narrower. The dodge has a shorter short side axle and tube. The dodge knuckle has the cast in steering arm up higher than the GM. Theres a light and heavy Dodge brake caliper(not sure about GM).
Nothing wrong with a Dodge D60 but it is a bit different than a GM. |
Member # 185461
4:10s (said in his OP) are the Dana 60. The Dana 61s use higher gears.
[QUOTE=f3arn0fj;13890184]No one hates you, you just walked into the lion's den dressed in that wierd lady Gaga meat outfit....[/QUOTE] [QUOTE=MaxPF;13897261] The new car smell is the most expensive fragrance there is... well, except [i]maybe[/i] for pussy :D[/QUOTE] |
Member # 18614
61 isnt a big deal. I have one on me schedule to rebuild. 60 gear's and spool with a spacer for the ring gear and some slightly longer bolts.
