Can't get 37" MT's to seat the bead - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-14-2012, 10:56 AM   #1 (permalink)
blakeape's Avatar
Member # 29868
I have a set of aluminum 16.5x9.75 wheels that I am trying to mount a set of the Goodyear Military 37x12.50R16.5 OZ tires to mount on. I have the tires on the wheels, but the sidewalls are so tough they won't push out enough to seal up and take air. I wish I had a picture, but am at work until tomorrow.
I need to push the beads out close to 3 inches to get them to seat/seal up. I have tried a ratchet strap around the circumference of the tire and the starting fluid /flame technique with no luck. What size wheels are you guys running with these tires other than H1's and any advice would be very appreciated.
Thanks
Jake
1996 Tacoma V6 5spd, duals, Dana 60, 14 bolt, 5:38's, 42" Iroks, exo-cage
1997 Dodge Cummins 5spd 4x4, 79 Dana 60 under leafs, Dana 80, 4:10s, 37's
/forum/tow-rigs-trailers/850288-1997-dodge-cummins-towho-expo.html
blakeape is offline   Reply With Quote
Old 02-14-2012, 11:01 AM   #2 (permalink)
Jules083's Avatar
Member # 123683
When I get the hard ones like this I take them to the tire shop. The guy I go to charged me $10 for all 4 when I brought my 42's in. They have better tools to take care of these problems.
Originally Posted by Lance
Will there be changes? I don't expect many, if at all
Forums will not change, administration techniques will not change one bit.
Ads will stay in the same places they currently are.
Jules083 is online now   Reply With Quote
Old 02-14-2012, 02:34 PM   #3 (permalink)
blakeape's Avatar
Member # 29868
I actually did go to a local truck tire shop and they tried everything they had including "Truck Blaster". They recommended I tube them which I don't want to do.
Thanks for the reply
http://www.pirate4x4.com/forum/showthread.php?t=850288
Old 02-14-2012, 03:41 PM   #4 (permalink)
Member # 53557
I used something like this:
http://www.amazon.com/Tubeless-Radia.../dp/B002KN04C4
but sized for a 16-17" rim when mounting up the 9R16 XL's I put on my M725. Had similar issues getting the beat close enough to the rim so that it would hold air and seat. That thing will fill that gap and pop out (run forest run) when the bead finally seats.
alosix is offline   Reply With Quote
Old 02-14-2012, 03:49 PM   #5 (permalink)
Jules083's Avatar
Member # 123683
This is going to sound dumb, but how about some heavy duty balloons? Stuff them in the tire and start filling them with the compressor. Maybe they would hold the bead out enough to get it to take air.
I'm just thinking out loud, I don't know if that would work or not.
Old 02-14-2012, 04:34 PM   #6 (permalink)
Member # 209905
Wedge a piece of wood in between the beads in a few places to spread them apart. Leave them in the sun or heat them up if you can.
Cocking the wheel so that you can close up the gaps some is helpful. Pull the schrader valve out and use a always open clip on chuck so you can use both hands to manipulate the tire. Sometimes you can use a tire spoon or big wrench to partially seat a bead too.
You can inflate a bicycle inner tube against the bead to fill big gaps too.
owenst7 is offline   Reply With Quote
Old 02-14-2012, 04:38 PM   #7 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
lol. i just went through this today. putting a set of 18 inch tires onto some nissan suv. these sidewalls were so smashed they looked like they been sitting at the bottom of a tire pile for 8 years. and tried for 30 minutes on a tire machine
and as was instructed above is what got them out. stand on the inside bead, pull the tire up to you an put a 4x4 piece of wood in there that will barely fit and let it sit. i got away with doing it for about 30 minutes but barely, i got lucky. but yeah if you arent in a hurry let it sit like that for a day or so
Originally Posted by Lance View Post
Since you perverts have a billion porn videos posted in the TP, I've disabled the function in the TP. It works everywhere else.
abig84 is offline   Reply With Quote
Old 02-14-2012, 08:32 PM   #8 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Here you go..
Inflate a Tire with Liquid Fire TRICK - YouTube
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 02-15-2012, 05:46 AM   #9 (permalink)
mega hack!!
sjracer's Avatar
Member # 139150
x3...... i have had to do this myself. let them sit and get nice and hot in the sun with the blocks in place. then only remove the blocks as you mount each tire.
the other thing i've done is to force seat the lower bead onto the the rim bead ring using the tire machine. only certain machine rotary types of tire machines will do this though.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's!
/forum/chevy/933618-new-old-black-getting-1-ton-makeover.html
sjracer is offline   Reply With Quote
Old 02-15-2012, 06:16 AM   #10 (permalink)
Member # 208297
Originally Posted by HAPPYJOHN View Post
Here you go..
x2. always works for me!
xcwes is offline   Reply With Quote
Old 02-15-2012, 06:47 AM   #11 (permalink)
Elwenil's Avatar
Member # 41063
Take them to a truck tire shop and let them put a Cheetah Tank on it. About the only safe way to get them to seat. The ether trick works too if you aren't putting Airsoft BBs in for balance like I did, but after fighting with mine for a day, I happily paid a truck shop $50 to mount my 5.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s
Elwenil is offline   Reply With Quote
Old 02-15-2012, 06:50 AM   #12 (permalink)
Jules083's Avatar
Member # 123683
OP said he tried it. I've had it not work a few times, some tires just don't want to be mounted.
What about putting a tube in and setting the beads, or at least air it up until the back bead seats. Break one bead, remove the tube, and put the valve stem back in. With one bead seated you should be able to push the tire down enough to get the other side to seal.
Old 02-15-2012, 06:56 AM   #13 (permalink)
Jules083's Avatar
Member # 123683
I quit messing with my own tires a while ago for the most part. My guy charges me $20 to mount and air up 4 tires as long as I help him out with moving them around. He's an older guy, 42's are a bit much for him anymore. I still do 33" and under Radials myself, anything bigger or Bias ply goes to him.
Old 02-15-2012, 12:41 PM   #14 (permalink)
Member # 106427
Most truck tire or equipment tire shops have this stringy thick ass looking greese stuff the pack into large gaps. As the tire fills up it pushes it out.
Jenks
jenks21 is offline   Reply With Quote
Old 02-15-2012, 12:49 PM   #15 (permalink)
Dooley's Avatar
Member # 87818
before trying to mount on rims, i put innertubes in mine, filled them up till the sidewalls were somewhat ballooned out then let them sit in the sun for a day, worked great
Dooley is offline   Reply With Quote
Old 02-15-2012, 04:05 PM   #16 (permalink)
POOPSMITH
abig84's Avatar
Member # 88383
heres a picture of the wood technique i had to do yesterday
and the stupid part was that thing was stretched out ready to go. but the guy whos car we bought these tires for (hes a wholesaler we do alot of work for him) decided to buy another tire but told him to take this one back, and the new tire was just as jacked up so told him to take his car back again and bring it back tomorrow after the new one is stretched out over night
Old 02-15-2012, 04:33 PM   #17 (permalink)
Member # 39639
16.5 tires suck as they have no safety bead to hold the tire on the rim in the event they lose air. Whenever I have trouble with them I put a flow through chuck on the valve stem. I then place the wheel on a 5 gallon bucket with the front of the wheel facing down. Doing this makes the gap be on the backside of the wheel which usually results in a much smaller gap. A quick blast of air with the cheetah usually gets it. Whenever you do get them seated make sure you keep a good amount of air in them as 16.5s love to pop off the bead if the pressure gets too low. People that work at tire shops love people that put the blocks of wood in between the beads on tires that are crushed.
3.slowt100 is offline   Reply With Quote
Old 02-15-2012, 04:46 PM   #18 (permalink)
Member # 39639
You can also use the starting fluid method with the tire/wheel face down on the bucket as well.
Old 02-15-2012, 05:26 PM   #19 (permalink)
Member # 31206
When i had my GY military 37's mounted at the shop they had a hell of a time getting them to seat also. took 2 guys, one blasting with the cheetah and one filling on the valve. still took them a few tries per tire
Samurai, yota's, locked geared, yj's ect
AfflictedPast is offline   Reply With Quote
Old 02-15-2012, 05:31 PM   #20 (permalink)
HAPPYJOHN's Avatar
Member # 119290
Ding,ding,ding.
The ether trick DOES require one bead to be resting against the rim.
( not rim/tire lying on ground )
Old 02-15-2012, 05:59 PM   #21 (permalink)
grnd93's Avatar
Member # 64925
Send a message via MSN to grnd93
Jenks
Gorilla snot, used to use this stuff all the time when I was busting tires
Originally Posted by void_of_light
Somewhere in the Canadian wilderness, the new owners are questioning their decision to buy a forum filled to the brim with assholes.
grnd93 is online now   Reply With Quote
Old 03-06-2012, 10:40 AM   #22 (permalink)
Registurd Abuser
'71 800B's Avatar
Member # 34995
I used a 16" bicycle tube. works but takes some time. I keep it in the rig just in case I pop a bead.
'71 800B is offline   Reply With Quote
Old 03-08-2012, 06:17 AM   #23 (permalink)
Hey Yall Watch This
Country69's Avatar
Member # 204026
O.K. I'm ignorant. If you use a full size tube to seat a stubborn bead. Why would you remove it?
Country69 is offline   Reply With Quote
Old 03-08-2012, 06:33 AM   #24 (permalink)
Member # 130014
long (er) ago, tireshops had those really thickwalled tubes that went between the rim and the bead in question, sealing the gap. after one bead was seated, the other one just slowly pushed the lubed up tube out as the tire inflated......
point being, we made one out of foam pipe insulation, taped into a donut for placing in the bead to help seal it, and it does nearly get smashed but always gets pushed out.
if that makes any sense, always worked for us.
:D
SKULLYOTA is offline   Reply With Quote
Old 03-08-2012, 07:45 PM   #25 (permalink)
Fistful of Boomstick
usmcdoc14's Avatar
Member # 13344
Send a message via AIM to usmcdoc14 Send a message via Yahoo to usmcdoc14
try harder
(this is setting the same combo you are asking about)
Setting the bead of a tire using FIRE !! (starting fluid) - YouTube
Doc-14 Tactical Products:
When it absolutely, positively needs to be made from random crap found in the back of my garage.
You cant ban knowledge, learn to make your own guns right Here.
New York, Colorado, Maryland, Conneticut….is your state next? Yes it is. Write, Vote and Fight.
usmcdoc14 is offline   Reply With Quote
