What size is the ujoint on a dana 300 t case and on an 87 4runner drive shaft? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2012, 12:23 AM   #1 (permalink)
Member # 94383
I need a u joint to hook the two up. Any ideas? Flange is coming off the drive shaft and stock shaft if I can find the right u-joint should be able to go to my dana 300 for my build.
[COLOR="red"][B]6" nylon filament cup brushes for grinders only 25.99 shipped via 2 day![/COLOR][/B] [url=http://amzn.com/B004OI9FFA]Buy it here. It is great for easy surface prep for DIY bedliner, cleaning, and welding![/url]
[url=http://www.painfreemerchandising.com]Need help selling online? Contact Pain Free Merchandising[/url]
1967 M35A2 FOR SALE
2007 Cayman
1987 4Runner
mrarmyant is offline   Reply With Quote
Old 02-18-2012, 03:17 PM   #2 (permalink)
Banned
Member # 138976
any reason that you can't set up the d300 to run a drive flange? then just use the stock toyota joints and drive flange pattern?
Just a thought.
Provience is offline   Reply With Quote
Old 02-18-2012, 04:04 PM   #3 (permalink)
Member # 69594
I'm pretty sure there is a flange available for the D300 to bolt the Toyota stuff up to it, I looked into it for a project a while back but I'll be damned if I can remember who was making it.
Nothing happens when you die.
TrikeKid is offline   Reply With Quote
Old 02-19-2012, 11:38 PM   #4 (permalink)
Member # 94383
I htink I found a flange that isn't 100 dollars that could work. I like that idea.
1967 M35A2 FOR SALE
2007 Cayman
1987 4Runner
Old 02-20-2012, 05:17 AM   #5 (permalink)
Banned
Member # 138976
Another, possibly more ghetto option:
Take the d300 yoke, cut off the splines, weld on a pices of plate, drill for driveshaft pattern on plate, run chepo hommemade flange.
The toyota flanges align center off of the center bore more so than the bolt holes, so it would be nice if you could get that dimension correct, but assuming you get that one, the rest of it wouldn't be so bad.
Never tried, just popped into my head, so it may be full of issues
Old 02-20-2012, 09:26 AM   #6 (permalink)
Member # 94383
Not a bad idea for a trail only rig but this will be streeted. I doubt I can get it concentric.
1967 M35A2 FOR SALE
2007 Cayman
1987 4Runner
Old 02-21-2012, 04:44 PM   #7 (permalink)
Member # 25321
Send a message via AIM to myndphuct
Jesse at High Angle Driveline sells Dana 300 Drive Flanges with the toyota pattern.
http://highangledriveline.com/toy_flange.html (This link is for the Dana 44 flange, works with the 300, same splines)
WFO Concepts as well
http://www.wfoconcepts.com/pr/Dana-4...3210/3311/3322
Google Dana 300 to toyota flange there are a few others as well.
89 yj, AMC 360, TF727, Stak D300 RAC, Waggy 44 front/mini spool, Toy 8" locked rear. 35" Krawlers.
myndphuct is online now   Reply With Quote
Old 02-24-2012, 08:35 AM   #8 (permalink)
rstycj's Avatar
Member # 125507
Toyota= 1.14" caps, 2.05 across and Jeep= 1.063 caps, 3.22 across
78 cj5 350sbc sm465
97 one ton s10 in the works
rstycj is offline   Reply With Quote
