Member # 78288
Turbo or sc?
Thinking about putting a turbo on my 2011 silverado 4.3
Wanna run about 6psi. What's a good sized turbo, and should I run an inter cooler? Tune isn't a problem, but will I need a bigger fuel pump My buddy is a diesel guy so he knows a good bit, he will be helping me. What all do I need? I have factory electric fan so I have room. What do I do about the turbo manifold? I'm not looking for big horsepower numbers, I want maybe 50-75 extra Hp. Also can it be set up to where you don't hear that gay woosh when I let off the gas? I hate the way the turbo ricer bov sounds I'm kinda dumb when it comes to turbos. Or is there a supercharged that will fit? I've heard that 96-98 5.7 sc kit will fit on a vortech 4.3 that true?
86 k20 350/400/205/d44/14bff |
Member # 78288
Thought about a 5.3/6.0/6.2 swap but I want something different. Turbo would increase my power and still leave some economy. I want to be at about 275-300hp. About 80-115 more Hp at the most. I'll be towing with it as well. Within my trucks towing capacity of course. It's my tow rig for my k20.
I don't know what turbo to get. Would like it to spool at lower rpms(2500-3ish). But not fall on its face in the higher rpms
Member # 78288
Also what do I need for a turbo set up. Intercooler needed for 6-8psi? Should I buy a kit for a 5.3 and mod it to work? Or start from scratch? The lot I was looking at is this
http://ststurbo.com/gm_trucks
Member # 180131
http://www.pirate4x4.com/forum/showt...205&highlight=
Check out this thread. I know that jpfrk2001 used a Jeep engine but all the principles apply to your engine as well. jpfrk2001 also gave me these links to turbo books to check out. http://www.barnesandnoble.com/w/stre...ner/1102224620 http://www.amazon.com/Maximum-Boost-.../dp/0837601606
0100011001010101010000110100101100100000010011110100011001000110 '99 hamster powered TJ- for sale |
Permanent Newb
Member # 176672
Def check out these guys:
http://www.ststurbo.com/gm_trucks Keeps the smog guys happy, and even have the programmer to take care of your computer, I've used the universal kits on a ton of stuff and always been happy. Most of the time it's even cheaper than junkyard piecing together crap, and an EZ weekend install
#12 (permalink) |
Newbie
Member # 101018
From my experience of building import cars with turbos, there are a few things you really need to look at. Such as will your stock fuel system supply enough fuel for the increase in air flow. Will your MAF do well with the increase in air flow. Like mentioned before you will need either a chip for your ECU or a SAFC, which overrides your ECU to allow more fuel but does not compensate for timing.
Don't forget you will want an intercooler, and an A/F ratio gauge is not a bad idea also. There is alot more to it then just getting a manifold and slapping on a turbo, plus you will want a fresh bottom end or pistons designed for boost. The ring landings on pistons designed for boost are lower then N/A applications. The gay woosh is the sound of the blow off valve, which releases pressure when you let off the throttle so that you don't get compressor surge, which can destroy a turbo over time. For 6 PSI I would run a small turbo, basically the smaller the hot side of the turbo the quicker it will spool and reach maximum flow, although for 6 PSI you could run damn near anything a little bit bigger then a 14b.
Just because you can, doesn't mean you should... |
#13 (permalink) |
Member # 78288
I have a tuner that specifically deals with gm trucks and have that part under control. I'd like to run stock internals til it goes. I think my stock pump should be fine. It's the same as in the 4.8/5.3/6.0/6.2 so it should work. I know I need a bigger Maf and injectors. I'm no exPert when it comes to turbos. So I'm not sure of a good size. T3?t4? Hx35?
Also is there a way to get a bov so it doesn't whoosh(like on diesels)?
#14 (permalink) |
Newbie
Member # 101018
Most diesels don't have a blow off valve, IIRC it's because of the low RPM's and boost. For turbo size honestly you can run whatever you want. Small turbos spool quick, but max out quicker, big turbos spool later and can support higher RPM ranges.
#15 (permalink) |
Permanent Newb
Member # 176672
Your standard Hypertech tuner won't know what to do with positive boost, you'll need a specific program and MAP/MAF sensor for that (not bigger, 1bar). Lean=death.
Your fuel pump will probably be OK with 6psi, but you are right on the edge for stock injectors. I'd get a slightly bigger set for sure. Lean=death. A small turbo is better for you because you're not filling a huge engine, and quick boost rules! T-3/T-4 doesn't describe anything but the housing size. A turbo that small might not even need a blow-off valve, but yes there are quiet ones too and good for you on that choice
#16 (permalink) | |
Member # 22176
Look for a under hood kit. Find a syclone/typhoon shop if you can't find a kit. They had turbo 4.3's. Parts may swap over. A roots type sc will not fit a 4.3. A centrifugal may fit, but will likely over boost. A pully swap will be needed minimally.
I can break a steel ball in a rubber room! Last edited by Beat95YJ; 04-06-2012 at 02:58 PM. |
#17 (permalink) |
Permanent Newb
Member # 176672
Curious to why you think that? Any personal experience? or are you just making a bandwagon assumption because they're different?
Good suggestion on the Cyclone/Typhoon shop, but since those were VERY low production trucks I don't think he'll fine a specialty shop in his backyard, I didn't search though. How about a Typhoon club? Those guys are nuts about them and might have the low down. Last edited by Cooter!; 04-06-2012 at 03:01 PM. |
#18 (permalink) | |
Member # 22176
We were evaluating boosted kits on that car and that was a least favorite.
I can break a steel ball in a rubber room! |
#20 (permalink) |
Gearhead
If your still considering a sc here's a company with a bolt on kit.
http://www.tbi-superchargers.com/TBI...ercharger.html
Check us out on facebook. http://www.facebook.com/FnMagicMotorsports |
#21 (permalink) | |
Permanent Newb
Member # 176672
). They even say rain is far from an issue. Oh well, to each there own.Sounds like the OP wants to junk yard build it anyway. |
#22 (permalink) |
Hardcore Web Wheeler
Member # 102426
Meh, I'm a fan of roots, I like instant boost. Eaton M-90 or 112, would be plenty for 6 psi on a 4.3. Easily found in boneyards for cheap.
Yeah, it takes some fab work. If a little fab work is too much for you then you are on the wrong forum.
The Answer to 1984 is 1776 |
#23 (permalink) |
Member # 78288
Th tuner I meant was a person. He will throw it on the rollers to tune it. Not a handheld job. That kit from Tbi site that was linked. Will it work on a non Tbi motor?
