Member # 99868
hey guys, I'm having an issue with my speedo cable on my 85 k5... I just finished swapping out my 700r4/208 to sm465/205. The speedo cable never really worked with the old setup (700r4/208) and then I put the sm465/205 in and it worked for a little bit but then got a twisted up and trashed down where it connects to the t-case somehow...
So I got another speedo cable and installed it and it worked for a few drives and then just stopped working and haven't got it to work since. When I get under my rig and unhook it from the tcase it still has the square shape to it so it's not stripped or anything and when i spin it around my buddy says the speedo kind of tweaks a little bit which must mean that everything from there on up should be connected correctly. I personally think that it could somehow be the connection between the 205 and the speedo cable...? any ideas fellas? this thing has been haunting me, sorry for the long ass post! |
#3 (permalink) | |
Addicted to Gear Oil
Member # 56050
Use a drill to spin the speedo cable and make sure the speedometer actually works, and there's no kinks or severe bends. If that checks out, it's probably the speedo drive gear, the one that drives the cable is metal, but the gear that is on the tailshaft/rear output is plastic, might have some stripped teeth. You can unscrew the speedo drive and use a flashlight to inspect the plastic gear. It's pretty easy to replace, pull the yoke, rear bearing retainer and bearing, and slide a new one on.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016Last edited by guidolyons; 04-08-2012 at 11:40 AM. |
Member # 46175
I have seen the square drive break off at the back of the speedo as well.
Edit: It would work intermittently.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST Specializing in Axles and Transfercases |
#5 (permalink) | |
Member # 99868
Is there a simple fix? or do I have to buy a whole new speedo cable? bare with my guys, thanks for all the help! |
