Anyone running a Holley with off road needles and seats? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-07-2012, 08:31 AM   #1 (permalink)
Member # 173513
I'm running a q-jet on my truck now but I'm wanting to upgrade the intake heads and cam and I'm going to need a better carb is anyone havering good luck with a holley? It's going to be for trails and hill climbs.
5 Ton Cummins slow but steady.
cobramustang331 is offline   Reply With Quote
Old 04-08-2012, 08:01 AM   #2 (permalink)
Member # 78288
What engine is it? Mostly stock modded?
Reason I ask, was I too ran a truck avenger and it sucked on the street, and ran either too rich or too lean. Never could get it right. Sucked on mpg's too. But offroad it never starved for fuel or flooded.
I took it off and got a motorcraft 2150 and rebuilding it. Already has spring loaded needles and seats. Never had a problem with it neither. Went from 12 to 18 mpg's
86 k20 350/400/205/d44/14bff
The_Dealer is offline   Reply With Quote
Old 04-09-2012, 07:28 AM   #3 (permalink)
Member # 129677
Q-Jet backwards is the best carb to run offroad. Holley's flat out suck on anything but level concrete...
jeepman1320 is offline   Reply With Quote
Old 04-09-2012, 08:02 AM   #4 (permalink)
Member # 78288
Backwards? How does that work out?
Old 04-11-2012, 09:54 AM   #5 (permalink)
Member # 129677
Just like it sounds. Primary's towards the firewall. Use a square bore intake with a q-jet adapter turned backwards. There are several threads on here and on the web on how to do it. Mine will idle while sitting almost on it's tailgate, granted it runs rich, but still works. Only problem I have had so far is fuel spillage at really bad angles.
