newb wheel size thread.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-16-2012, 10:57 PM   #1 (permalink)
Member # 200324
I picked up some 33's for my 83 toy. I have 2 that are 33/14.5/15 and 2 that are 33/12.5/15...Can I use the same rim width for all 4? I was thinking a 15x10 but I am not a hundred percent sure.
2002 Dodge 5.9HO 6sp
2005 Honda Pilot on 31's
83yotski is offline   Reply With Quote Quick reply to this message
Old 04-16-2012, 11:36 PM   #2 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Short answer; Yes. The only caution that I would throw out there is that if you run a two inch wider tire on the same width rim, the actual outer diameter will be different. this being the case, do not engage the four-wheel drive while on dry ground. The different diameter will cause the drive shafts will turn at different speeds, which will damage the transfer case.
Dana 60 or 14 bolt disk brake kits $315 shipped
I'd call you a cunt but you don't have the depth or the warmth.
HAPPYJOHN is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 06:52 AM   #3 (permalink)
Hey Y'all Watch This
Country69's Avatar
Member # 204026
In addition to what HAPPYJOHN said I would also put the wider ones in back, if you did not already think of it.
Country69 is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 07:06 AM   #4 (permalink)
Member # 200324
Wider defiantly going on the back. I have no use for 4wd on pavement. Just curious, what size room do you think it would take to even it out though? 15x10 for the 12.5s and 15x12 for the 14.5s?
Old 04-17-2012, 04:27 PM   #5 (permalink)
Member # 123683
Just run the same rim front and rear, it'll be easier later when you need new tires. It's hard to guess that, because every company measures their tires a bit differently, and they rarely measure out to what's printed on the sidewall. You might even consider a 15x8, that's what I always use for the 12.5's.
Jules083 is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 05:24 PM   #6 (permalink)
Wild Hare's Avatar
Member # 75473
you can run different air pressures front and rear to even out the height of the tires
lead or follow, it doesn't matter. Just get the F@#$ out of my way!
Wild Hare is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 10:37 PM   #7 (permalink)
Member # 200324
Is this sarcasm....if this will work awesome...if not, I feel like a moron and will go back to lurking lol.
Old 04-18-2012, 05:31 AM   #8 (permalink)
Wild Hare's Avatar
Member # 75473
Yes it works. Guys do it all the time when they run a smaller spare than whats on their rig.for example.running 35's and only having a 33 spare they run max pressure in the 33 and lower the pressure in the 35's to match the heigth of the 33
