I See You
Member # 138976
Depends on application. I am running a g52 trans 22r 37" tires. It performs close to stock on the road with 5.29s.
For a trail only rig you won't notice much difference, properly setup in a reasonable rig they will both last. |
Piggin' Ain't Easy
5.71s are VERY sensitive to proper setup, good bearings, proper bearing preload.
That said, If set up correctly (i'd suggest using v6 3rd members for the larger bearings/heavier casting), they are/can be just as reliable to 5.29s. EDIT: I prefer running 4.10 gears for their inherent strenght, I beat the total hell out of my rig, and still break 4.10 from time to time (along with 30 spline longs and tcase outputs)
Nick Cooper StockRunner build (stock height link suspension) turned firewall buggy Gremlin build - small ugly linked beater truck Last edited by TBItoy; 05-07-2012 at 06:26 PM. |
Way tougher than you
Member # 141446
As others have stated, if set up correctly, 5.71's can last. But take a look at how small that pinion is.............YIKES! No bueno. Stay with the 29's.
I carry a gun, because a cop is too heavy ECV 3-Lord Sholto Douglas |
Member # 1418
read this .........
http://www.gearinstalls.com/410suck.htm
Arizona Trail Riders ....... BRRRaaaAAAPPPPPPP |
#7 (permalink) | |
Member # 141446
