Jeep has a vibration under load - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-29-2012, 02:48 PM   #1 (permalink)
Member # 89087
I have a 2004 Jeep Wrangler and it has a bad vibration under load above 2500 rpm. The clutch has been replaced and it didn't help, however it definitely needed to be replaced. The jeep has about 75000 miles on it. What could be causing the vibration?
Thanks,
Brittain
greatb15 is offline   Reply With Quote
Old 05-29-2012, 04:01 PM   #2 (permalink)
Elwenil's Avatar
Member # 41063
Check the U-joints and yokes and the engine and transmission mounts. Then go through the suspension to see if anything is loose.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s
Elwenil is offline   Reply With Quote
Old 05-29-2012, 04:33 PM   #3 (permalink)
Member # 78288
U joints
Put it in nuetral on flat ground with the ebrake on, and grab the shaft and shake it and check for play. Shake it in a cross patter like the ujoint is made. I'd I ahead and replace em, they don't always have play when thy are bad. On a rig that old its worth the 9 bux each you would spend. Also stick something between the Trans mount and skid and check for play. My vote is u joints. I speak from jeep u joint experience lol
86 k20 350/400/205/d44/14bff
The_Dealer is offline   Reply With Quote
Old 05-29-2012, 09:49 PM   #4 (permalink)
Member # 63800
Originally Posted by The_Dealer View Post
U joints
what this guy said. neutral, parking brake, shake, isolate, replace.
"I’m more flux-core than hard core." -- rustywagoneersdotcom
OffRoad is offline   Reply With Quote
Old 05-30-2012, 01:16 PM   #5 (permalink)
Member # 89087
Thanks I'll check them when I get home tonight.
