Solid Axle Camber Adjustment? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-04-2012, 11:47 PM   #1 (permalink)
Member # 108492
Can you adjust the camber on a solid axle?
If so, how? The only way I can think that you might be able to would be with a torch to heat the tubes and set it that way. . .seems like camber for a solid axle is something that once it's set that's what you've got.
Thanks!
1994 Jeep YJ Wrangler, 1979 Ford F-150 4x4, 1949 Jeep Willy's P/U Truck
atomicjoe23 is offline   Reply With Quote Quick reply to this message
Old 06-04-2012, 11:55 PM   #2 (permalink)
Elwenil's Avatar
Member # 41063
If you are talking about a front axle, there are bushings that will offset the upper ball joint as well as spindle shims that can change it a bit. If you have a bent axle housing, probably the best thing to do is just replace it.
1988 Dodge AW450 Ramcharger-318TBI-NP435-NP205-D60s
You are experiencing technical difficulties.
Elwenil is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 12:00 AM   #3 (permalink)
Member # 17904
eccentric bushings on kingpins, eccentric inserts for ball joints
HalfFastFord is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 12:02 AM   #4 (permalink)
Member # 108492
OK. . .thanks.
Just wondering for future reference. . .
Old 06-05-2012, 12:24 AM   #5 (permalink)
v6toy4x's Avatar
Member # 9154
so who has these balljoint eccentrics
85 4rnr hi-pin e-lkr, hi-pin detroit 9" w/toy front discs, R151,redbox,d300 4:1,
98.5 dodge-edge EZ, TST p-maxIII, ex brake,Goerend trans,ford outers,quad air bags
'05 arctic fox 1140-cameras,SS bbq and stove,280wts solar,inverter,cocktail cubes 24/7
'01 21.5 boat w/502 "Evil Satisfaction"
v6toy4x is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 12:56 AM   #6 (permalink)
Member # 17904
http://www.partsgeek.com/catalog/199...r_bushing.html
Old 06-05-2012, 07:33 AM   #7 (permalink)
Hey Y'all Watch This
Country69's Avatar
Member # 204026
Well Now, those are cool
Country69 is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 09:12 AM   #8 (permalink)
Permanent Newb
Cooter!'s Avatar
Member # 176672
FYI, for rear axles, there are 4 bolt shims that will bolt between the backing plate and flange for minor adjustments too.
If the answer to your diagnostic test is indeterminate, you must enlarge the context of the question.
Peterson's 4 Wheel & Off-road UA2014 Alumni.
Cooter! is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 04:53 PM   #9 (permalink)
Elwenil's Avatar
Member # 41063
How is angling the brakes going to help with alignment?
Old 06-05-2012, 05:00 PM   #10 (permalink)
Permanent Newb
Cooter!'s Avatar
Member # 176672
Because thats what your wheels bolt to. EDIT: ohhhhh, you mean disk brake caliper brackets don't you? Not clear in your post. I mean drums, or rotors but only with a bolt-on spindles, you are actually meant to bolt this shim between the SPINDLE and the tube....
Depending on the orientation of the square, you can change camber (+or-) or toe.
Not for FF axles obviously.............
Edit: I thought these were pretty cool too!
http://www.lightracing.com/products/...f-road-fastrax
Old 06-05-2012, 05:14 PM   #11 (permalink)
Member # 13731
Camber angle on front axles can be adjusted with shims that go between the spindle and the knuckle.
The eccentric balljoint sleeves can do both camber and caster depending on which way you rotate them.... But on the Dana 44 ones you may have to accept a less than ideal preload on the balljoint to get them lined up where you need them.
uglyscout is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 05:41 PM   #12 (permalink)
Elwenil's Avatar
Member # 41063
No, either way won't matter. On a semi-floating axle, the wheels don't bolt to the brakes, they bolt to the end of the axle shaft. If you shim behind the backing plate on drum brakes all you are doing is shifting the backing plate and shoes around. The drum is still mounted to the axle flange as well as the wheel and will still run true to the axle housing. You will just wear the brake shoes and drums really odd and have them drag all the time.
To adjust a semi-floating axle, you would have to actually move the axle shaft around in relation to the axle tube. To get more camber, you would have to shift it higher in the tube and hope that there is enough play in the splines at the differential end to deal with the misalignment. To do this with a C-clip axle, you would have to re-machine the end of the housing.
Shimming works with an independent rear or front axle with a separate spindle that can be unbolted and shimmed for different angles but I don't think you would ever really be able to change a solid rear axle. If I am wrong, please post up an example of this and I will review it.
Old 06-05-2012, 07:36 PM   #13 (permalink)
Member # 46175
Please quit posting.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 09:15 PM   #14 (permalink)
Permanent Newb
Cooter!'s Avatar
Member # 176672
Originally Posted by Elwenil View Post
Shimming works with an independent rear or front axle with a [COLOR="red"]separate spindle that can be unbolted and shimmed for different angles[/COLOR}but I don't think you would ever really be able to change a solid rear axle. If I am wrong, please post up an example of this and I will review it.
I have no example of a solid rear axle because that is NOT what my post said.
Your first post was unclear, hence the confused reply.
You can jump to whatever conclusion you think, but we are both right...
Old 06-05-2012, 09:27 PM   #15 (permalink)
Member # 133589
Just shut up
I hate everybody, don't it feel great.......... to hate?
mvanhelden is offline   Reply With Quote Quick reply to this message
Old 06-05-2012, 10:24 PM   #16 (permalink)
Elwenil's Avatar
Member # 41063
I guess you missed the whole part of this question being about SOLID AXLES.
Old 10-27-2012, 07:01 AM   #17 (permalink)
MAster-O-Turbonics's Avatar
Member # 198027
Send a message via Skype™ to MAster-O-Turbonics
Thanks!
Torch and a bunch of rags soaked in ice water is how we fine tuned camber on circle track (the 190 mph stuff) full floating 9" rear ends. Never tried to go more than .5 degrees or we would just swap to a different housing.
That was with ball type outer splines as well...
MAster-O-Turbonics is offline   Reply With Quote Quick reply to this message
