Member # 102974
Steering Stab Mounting Spacers
I have a Radflo steering stab, that I need new spacers for both mounting ends
5/8" rod, 2" body, and 22-7/8" approx extended length Both bushings are 1 3/8" each, or about 11/16" each...........problem is, that a 1/2" bolt will not go through these bushings, about a 1/6" too tight ![]() ![]() The ends of the stab will take and accept a 1/2" bolt I bought a 4 pc spacer kit, which came with two tall and two short spacers. But the 1/2" bolt will not go through the bushing kit......and my bracket that it bolts to is drill out for a 1/2" bolt The shorter two spacers I have pictured work good and accept a 1/2" bolt, but they are obviously much shorter than the other 4 spacers I have pictures......if I use the shorter two, there is too much slack/slop in the bracket Should I just ream out the current spacers or are there spacers made for exactly what I need? ![]() ![]() ![]() Here is the bracket I am going to mount one end to: ![]() ![]() ![]() Any ideas or suggestions?
'04 QC/LB, 4WD, 305/555 HO CTD, 37x13.50 Toyo MTs on BMF Sota 8, 6" Lift, MBRP 5", IceBox Intake, Air Dog 150, ATS Pulse Flow Manifold, BD Special Turbo, SMARTY SR POD, ARP Studs, T&C WILD Fuel Rail, T&C CPRV, II Dragon Fire 85% CP3, II 100HP Nozzles, Built 48RE, Bullet Proof Steering |
Member # 71891
cut off the part of the large spacers that go into the joint. then drill out the spacers to 1/2" make sure they are drilled straight.
not to be a dick but WTF is a steering stab?
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability 93 F250, 7.3T, ZF5 |
