Air shocks - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-25-2012, 11:02 PM   #1 (permalink)
Member # 197012
Air shocks
Going to be buying the trail gear rear three link for my toyota this summer, what's the deal with filling up air shocks with nitrogen and how does that depend On the lift and is there some sort of nitrogen kit to fill em up? Haven't researched more then 30 min so don't be to rough on me haha
82toyota4x4 is offline   Reply With Quote
Old 06-26-2012, 07:18 AM   #2 (permalink)
Member # 103868
You need someting like this.
http://polyperformance.com/shop/Syne...-Kit-p-56.html
SierraDave is offline   Reply With Quote
Old 06-26-2012, 02:17 PM   #3 (permalink)
MattyB4x4's Avatar
Member # 32726
That is a good, easy to use kit, but VERY expensive.
You can get nitrogen from local welding shops, and a regulator as well. You can then put a simple air chuck on the end of the hose and be done. Set the fill PSI, and pop it on....regulator does it's job and it's probably less than half the price of the poly kit.
5/8 Yotabuggy - duals + 4.7, 5.29's, locked, 40's, linked rear/fox airs, shift knob
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote
Old 06-26-2012, 02:24 PM   #4 (permalink)
Member # 123855
Send a message via AIM to ChemicalToilet
This is exactly what I did. Will need to get a hydraulic hose made to safely handle the pressure. At work they were tossing the braided stainless hose I used, so I didn't have to get the hose made.
Sent from my ADR6400L using Tapatalk 2
You stink and I don't like you.
ChemicalToilet is offline   Reply With Quote
Old 06-26-2012, 02:30 PM   #5 (permalink)
Member # 197012
Talked to a guy from lowrange offload and turns out the fox 2.0 air shocks come with 200 psi of nitrogen from fox, so all you have to do is dial them in from there. Sound about right ?
Old 06-26-2012, 02:38 PM   #6 (permalink)
Member # 123855
Yeah they definitely had pressure in them when I got them. I depressurized them so I could easily compress them for set up at full bump.
Old 06-26-2012, 04:32 PM   #7 (permalink)
Member # 197012
Here's what he sent me
http://www.pirate4x4.com/tech/billav...hox/index.html
It says in order to tune them right I will need to ad nitrogen, am I wrong?
Old 06-26-2012, 04:41 PM   #8 (permalink)
in Frank's mom's ass
toyoturd's Avatar
Member # 132582
ya for rears i ran 180-220 depends on angle where they are placed on frame and axle. pm me i have a set of used fox 16's ill sell
toyoturd is offline   Reply With Quote
Old 06-29-2012, 03:16 PM   #9 (permalink)
Member # 197012
I read somewhere you could add some compressed air into them for a few psi, do you think that the shocks coming with 200 psi is enough to not add any nitrogen
Old 06-30-2012, 01:51 PM   #10 (permalink)
Member # 188440
no loss chuck
you most certainly should not use a simple air chuck. we are not filling bicycle tires here. getting a tank and regulator from your local welding shop is your best bet price wise. for my hose i used a hydraulic plow hose with a 90 and a swivel. i think i paid $14, works great. i think its rated somewhere around 2400 psi so it will be suffice. for a chuck it should be the no loss type like this one http://www.ebay.com/sch/i.html?_nkw=no+loss+air+chuck
good luck
y-jay is offline   Reply With Quote
Old 06-30-2012, 03:09 PM   #11 (permalink)
whitwilliams74's Avatar
Member # 209340
I found my high pressure regulator & hose kit on eBay. Set up is designed for filling air shocks.
whitwilliams74 is offline   Reply With Quote
Old 07-03-2012, 03:46 PM   #12 (permalink)
Avalon Crawler
Member # 15221
good luck
I have filled mine countless times with a regular air chuck. I would overshoot when filling and use the adjustment tool with the "no loss chuck" from poly performance to bleed them down to the pressure I wanted.
http://www.polyperformance.com/shop/...ter-p-286.html
TJ on Tons...
ROBBY is online now   Reply With Quote
Old 07-07-2012, 12:20 PM   #13 (permalink)
Member # 188440
it seems like one extra step but if it works for you thats cool. you didnt mention that earlier so i assumed you used only the chuck. i know accuracy is pretty important.
Old 07-07-2012, 07:36 PM   #14 (permalink)
Member # 197012
found a company that will fill the pair of fox 2.0 shocks to 400 psi before shipping them to me, I thought you need to drain the completely, install them then fill them up?
Old 07-10-2012, 10:05 PM   #15 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
if you are just gonna buy them filled and run them honestly you are not taking advantage of why you are getting air shocks .. to get the most gain you need to be able to fill them and adjust the amount of oil in them
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
www.longfieldsuperaxles.com
www.kore4x4customs.com
www.ruffstuffspecialties.com
www.zukeviltwin.com
www.DEEPWOODSEXTREME.com
www.trailtough.com
supazuk94 is offline   Reply With Quote
Old 07-12-2012, 04:59 PM   #16 (permalink)
Member # 188440
what he said.
if your not into tuning, leafs are a good choice.
Old 07-17-2012, 05:06 AM   #17 (permalink)
Member # 68765
Send a message via AIM to King7765
I really like that "no loss" fill chuck thinger...
94 Ranger on 42's
My thread Here
King7765 is offline   Reply With Quote
Old 07-18-2012, 06:15 PM   #18 (permalink)
Avalon Crawler
Member # 15221
Maybe it's the regulator I have but it's not very accurate. So I would turn it up past what I wanted then adjust with the no-loss chuck to ensure I had the same pressure in each or in my case there was a slight discrepancy to the drivers side (ie. my fat ass in the drivers seat ) so my shocks on that side have a few PSI more (about 10) to compensate.
TJ on Tons...
Old 07-18-2012, 09:54 PM   #19 (permalink)
Piggin' Ain't Easy
TBItoy's Avatar
Member # 43587
Send a message via AIM to TBItoy
The actual pressure number in an airshock isn't really THAT important.
you are just using it to set ride height, you might have to put more in one side to get it to set level...if you are real fat or something lol
Now in a regular shock or coilover where you are not using the air as a spring, I make sure the shocks are charged the same.
TBItoy is offline   Reply With Quote
