4runner - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-16-2012, 03:01 PM   #1 (permalink)
Member # 142927
4runner
85-84 4runners are expensive .
how hard are 89-86 4runners to sas?
what is different aside from the ifs?
we already have a donor 81 toyota pickup
z1u2k3i is offline   Reply With Quote Quick reply to this message
Old 07-16-2012, 03:06 PM   #2 (permalink)
Provience's Avatar
Member # 138976
86-95 4runners are not very hard to sas, same as the pickups. Aside from the ifs, the front frame humps are a little different, the IFS frame with an sas will end up a couple inches taller than a SFA frame or 2wd frame.
Do not toss all of your IFS parts. The IFS axles are wider, so to make the 81 front match the width of the rear, use the IFS hubs and brake calipers, it is easy to convert to tacoma slip on rotors as well If you go to high steer, you will need to use the IFS steering box as well.
Rear up in the Toyota Bible/faq for tons more info.
To be clear, this is not to suggest that in similar circumstances, a person who engaged in this activity would face no consequences. To the contrary, those individuals are often subject to security or administrative sanctions. But that is not what we are deciding now.
- Comey on Clinton 2016
Old 07-17-2012, 06:39 AM   #3 (permalink)
Member # 221751
X2
And sell off the rest of the ifs for more money in the budget and a lot of cut off wheels and grinding disks cause your gonna need them
4runnedup is offline   Reply With Quote Quick reply to this message
Old 07-17-2012, 07:05 AM   #4 (permalink)
Member # 1418
Originally Posted by 4runnedup View Post
X2
X3
EFI is worth it when compairing doing a SAS..... even on a factory straight axle truck you pretty much do a SAS to get the better front hanger (ok you dont have to drill shackle holes in the frame)
Arizona Trail Riders ....... BRRRaaaAAAPPPPPPP
Kyron is offline   Reply With Quote Quick reply to this message
