Looking for a good road trip rig - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-08-2012, 03:47 PM   #1 (permalink)
Member # 225642
Question Looking for a good road trip rig
Currently, I have a 1990 Grand Wagoneer that I do like a lot, except for two big things, I can't afford to pay for a 10 mpg road trip to the Sierra Nevada with gas at $4.00 a gallon, and she tends to overheat. I discovered the overheating issue when me and some of my buddies took a trip to Hungry Valley OHV, which is about 100 miles away from where we live. We took two cars, my friend's lexus sedan and the waggy. It was 100 degrees going through the grapevine, and the waggy didn't like it at all, and we overheated going up the steep grade. We were almost up the hill, so when we cooled down we just climbed up the last few hundred feet and coasted down the hill from there. I know I could probably flush the cooling system or drop in a BJ's aluminum radiator, but with the waggy I feel like I'm burning money instead of gasoline. I love the car, but I think
I need something a bit more fuel efficient.
I've got a budget of about 3000 dollars, and i'm looking for a rig that can tow a small boat or trailer and fit a lot of people and camping stuff in. The 6.2 diesel suburbans look good on paper, as do the XJ cherokees, but I'm not sure the cherokee will be able to haul all my camping gear plus a small trailer. Any suggestions?
waggyneer is offline   Reply With Quote
Old 08-08-2012, 07:39 PM   #2 (permalink)
What did you expect?
HAPPYJOHN's Avatar
Member # 119290
Flush/replace radiator, install gear vendor or similar overdrive.
I don't think you'll find a reliable tow rig on that budget.
"Safety and security mean nothing without liberty." JamToy.
History teaches that all conquerors who have allowed their subject races to carry arms have prepared their own downfall by doing so.
-- Hitler, April 11 1942
Originally Posted by Roxywheels View Post
...... Shove a tissue in her nose, don't kiss her and hump on. ......
HAPPYJOHN is offline   Reply With Quote
Old 08-08-2012, 07:42 PM   #3 (permalink)
Elwenil's Avatar
Member # 41063
Ramcharger, but don't expect too much in the mileage department with any full size rig.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s
Elwenil is offline   Reply With Quote
Old 08-08-2012, 08:14 PM   #4 (permalink)
Member # 69594
Ford with a 6.9 or 7.3 IDI diesel should be in that price range, and they came in a crew cab format. Pretty good mileage and they'll pull a house, they just won't do it quickly.
Nothing happens when you die.
TrikeKid is offline   Reply With Quote
Old 08-09-2012, 01:41 PM   #5 (permalink)
Member # 225642
I'm liking the ford and gm diesels, but how do naturally aspirated diesels perform at altitude? To clarify, i'm probably not going to be towing much more than a tent trailer or 15 foot boston whaler, so its not going to be any heavy duty 10k stuff.
Old 08-10-2012, 01:20 PM   #6 (permalink)
chriscon7's Avatar
Member # 224978
The xj is probably not the best choice. Bad gas mileage for a 6cyl and won't like towing duty with a loaded cab either. i would look into older diesels so you can pull some decent mileage and load
6.5 turbo diesel
6.2 N/A diesel
7.3 pre turbo, or maybe early turbo models
maybe first gen Cummins 5.9
2006 Chevy Silverado 1500 4.8L nv3500 RCSB Z85 Flowmaster 40series
17” Baja rims 265/70/r17
chriscon7 is online now   Reply With Quote
Old 08-10-2012, 02:18 PM   #7 (permalink)
Way tougher than you
WYJAX's Avatar
Member # 141446
Do not overlook the XJ. We had an 87 while I was growing up and it was nothing special. Stock with the 5spd and the old man & I threw a small lift, 31's and some 3.73s in it. Had a factory TracLok in the rear end. We towed a tent trailer all over the Sierra Nevada's and never had any problems with it. It was our go-to rig when we weren't doing the tough trails. We would load it with 2 adults, 2 (sometimes 3) teenage boys, a dog, and all our gear along with the tent trailer and it worked flawlessly. That 4.0 is a torquey little motor. It's just easy to overlook these days in the world of the turbo deisel'd pickups. Plus, driven right, it can deliver low 20's for MPG when empty.
I carry a gun, because a cop is too heavy
ECV 3-Lord Sholto Douglas
WYJAX is offline   Reply With Quote
Old 08-11-2012, 02:01 PM   #8 (permalink)
Member # 225642
Another, potentially harebrained idea I've been thinking of may be to do an engine/tranny swap. I could get rid of the 360 and swap in a manual tranny and a 258 I6 from an older wagoneer, which I hear can get up to 18 mpg, or possibly keep the transmission, which is a chrysler TF 727 and put in a 5.9 cummins from an older dodge ram. I've never swapped an engine before, and I realize it might be a bit impractical, but what do you guys think?
Old 08-11-2012, 02:32 PM   #9 (permalink)
Elwenil's Avatar
Member # 41063
I doubt the front suspension and axle on a Wagoneer would enjoy dealing with the weight of a Cummins 6BT. A 4BT would be more than enough and a lot lighter, though they tend to be more expensive than the 6BT versions. Either is possible, though maybe not the ideal project for your first swap since it's not going to be a "bolt in" project by any means.
Old 08-11-2012, 07:45 PM   #10 (permalink)
Member # 225642
Yeah, I checked the weight of the 6bt and it's about 500 lbs heavier than the 360, which sucks because its the only Cummins I can find for a good price on craigslist. At this point I think Im going to go look at some xjs. They're plentiful enough, so I don't think I'll be looking too long to find a good one.
Old 08-11-2012, 08:57 PM   #11 (permalink)
Member # 130483
I would swap a late model GM 5.3L/4L60 setup and take the change and fix whatever doesnt work
now you also didnt say it had to be a 4x4
caprice/roadmaster wagons will tow and fit alot of people/stuff and get 20mpg hwy,old rwd volvo wagons are dirt cheap super easy to work on and do the same
92 S10,sm465/np208/np241,d44,9inch,spools,exo
99 Silverado,35's,locked 14b,4.8L,nv4500
92 s dime is offline   Reply With Quote
Old 08-11-2012, 11:31 PM   #12 (permalink)
Member # 225642
Thats true, I didn't, and I dig those roadmaster wagons! Maybe its just cause I'm partial to that fake woodgrain. I'll definitely look into some.
Old 08-27-2012, 04:05 PM   #13 (permalink)
Member # 204617
put the 3,000 into the wag. if you are going to do an engine swap, go for something more efficient, like the 5. 4l60 combo that was mentioned.
jamesdart is offline   Reply With Quote
