Member # 204236
Dually adapters?
I have a 1991 Toyota pickup that I'm building into a heavy duty off road firewood hauler. The idea is a compact and light truck that can haul heavy loads over rough terrain. I have 100 acres I'm allowed to cut on crisscrossed by overgrown logging roads, skidder trails, dry creeks, etc... I'm in the process of finding a rear axle to convert to a full floater to handle the weight, but I'd really like to put dual rear wheels under the flatbed. I found this old pic online from a Full Size Jeep forum of a dually adapter, but the company that made it has long gone out of business. I'm thinking of trying to find a local fabricator who could build a set. Might be $$$, but worth it I think. Anybody ever do anything similar with a Toyota?
Member # 178579
Frame strength isn't there, or I'd suggest swapping any old GM 10.5" 14-bolt FF, they're rated to carry 8,600#, they're everywhere, they're cheaper than those fail adapters you pictured, and it ain't that hard to adapt one to your spring spacing, driveshaft, brake lines, and shock absorber locations.
If you want to carry such loads, sell the 'yota and get a real dually. |
I See You
Member # 138976
Toyota made a factory 1-ton dually in the 80's. essentially the 2wd standard mini truck with Dual Rear Wheels, full floater axle and heavier springs. Look into that direction first.
Member # 41063
I believe the they made them through the '90s as well. There were many dually Toy U-haul trucks around here with the '90s cab at one time.
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s |
#6 (permalink) | ||||
Member # 204236
mega hack!!
Member # 139150
get a SRW full floater 14 bolt and haul your 4k easily. still the same width as a dually toyota axle and easy/cheap to find rims/parts for. easy to adapt to your frame.
ive worked on those toyota dually's for years. they bring the suck when it comes to getting parts. and those adapters your looking at are an abortion at best.
74 chev tbi 350 sm465/203/205 d60 ARB/14b detroit 56's/64's on 40's! ![]() /forum/chevy/933618-new-old-black-getting-1-ton-makeover.html Last edited by sjracer; 09-01-2012 at 08:27 AM. |
Member # 178579
Axle capacity isn't just the desired payload, it's also the weight of the rear half of the pickup itself.
For that, you need something rated to at least 6500, which is the upper limit of a FF Dana 60. I'm still gonna state that your 'yota frame won't survive that much weight with that much flexing. Box an S-10's rear C-channel frame, that might survive. |
