help please - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-12-2003, 02:47 PM   #1 (permalink)
Member # 16950
help please
i have an 86 K-5 blazer and have recently heard what sounds like grinding gears. it only happens when im traveling at speeds above 55 and only when i let off on the gas, it makes the sound for a few seconds and then stops. The same thing happens when getting back on the gas, there is also a clicking sound comeing from the rear diverside tire please help
86_Blazer is offline   Reply With Quote
Old 02-12-2003, 02:55 PM   #2 (permalink)
Pdaddy's Avatar
Member # 8133
The grinding thing almost sounds more like d line vibration to me, your ujoints cool? pinion angle correct? shake the rear wheel and see if it clunks pops or feels loose, wheel bearing??? Get under truck and get busy! LOL
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote
Old 02-12-2003, 03:16 PM   #3 (permalink)
Member # 16950
i checked the u joints and they are both fine, as for the wheel bearing do think that it needs replacement, but would that account for high speed noises? how do you check if the pinon angle is too much
Old 02-12-2003, 04:15 PM   #4 (permalink)
Member # 4737
jack the rear of the truck off the ground block the front and put it in nutral and roll a rear tire forward and backward to try and hear the noise. sounds like a u joint to me. is the truck stock height or how much lifted ?
1989 Chevy Blazer 350 V8
4x4realm is offline   Reply With Quote
Old 02-12-2003, 04:20 PM   #5 (permalink)
Member # 16950
it has a 4 inch suspension lift with 33 inch tires if it matters
Old 02-12-2003, 11:02 PM   #6 (permalink)
Member # 4737
Did you have the drive line extended after the lift ?
Old 02-12-2003, 11:47 PM   #7 (permalink)
Member # 16950
no
Old 02-13-2003, 01:00 AM   #8 (permalink)
Member # 2643
Yea it does matter if its lifted. Thats why he asked. Your problem is your splines on your slip yoke on the rear driveline are worn out. No stress until it was lifted. A quick fix if not to worn out is to fill it up with grease and keep jammed full of greese.
1985 TOY TRUCK, FULL BLOWN CHEVY 350 V8, DUAL 4 BRL EDELBROCKS ON A 6-71 WEIAND. RUNNING ON METHANE. 625+ HP. REAR DANA 70 WITH DISK BRAKES, 60 FRONT, WELDED & LOCKED, 44"BOGGERS, FULL HYDRAULIC STEERING, RADIATOR IN BED, TILT FRONTEND, W9000I ( YES IT IS BUILT MOSTLY FOR ROCKCRAWLING, WITH A LITTLE EXTRA HP ). www.4x4realm.com
TEAM X-TREME is offline   Reply With Quote
Old 02-13-2003, 03:24 PM   #9 (permalink)
Member # 16401
Send a message via MSN to kd7srj Send a message via Yahoo to kd7srj
get under it with the wheels blocked and in neutral grab your rear driveline and jerk it hard and see what moves and doesnt twist...sounds like a pinion bearing but i cant hear it from here!
85 toyota P.U.caged, Bobbed, chevy rears, 529's
,rearmains up front, spools, crossover steering, limited to 33's till I get longfields, changing birfs on the trail sucks.
kd7srj is offline   Reply With Quote
Old 02-13-2003, 05:15 PM   #10 (permalink)
Member # 16950
thanks all for the help, unfortunaly i have to wait until i get home during spring break to check things but thanks all
