Member # 8883
I have heard you can run 1% on the road and 2% difference off road, with no adverse effects, per Randy of Randy's Ring and Pinion.
"as long as the front and rear ratios are within 1% that the vehicle works just fine on the road, and can even be as different as 2% and work just fine off-road with no side effects" Jeremy |
you'll be fine with 4.10's in one axle an 4.11's in another, because if you divide the number of ring gear teeth by the number of pinion gear teeth it isn't always going to give you exactly 4.10 or 4.11, those are usually numbers rounded to the nearest hundreth.
99' ZR2 Blazer, SFA 79' F250 Dana 44 with chevy outers, 4.88's detroit, 14 bolt FF, 4.88's, detroit, 3.5" YJ springs in front, customs in rear, 36" TSL's |
Member # 5516
The reason for the very slight differences in axle ratios like 4.10 and 4.11 is because of the slight ring gear diameter difference between the front and rear axles. It's just not cost effective for the gear manufacturers to try and make the ratio exactly the same since that slight .01 or so difference doesn't affect anything.
Member # 6234
the difference between 4.10 and 4.11 is that 4.10s have 41 ring gear teeth and 10 pinion teeth. 4.11s have 37 ring gear teeth and 9 pinion teeth. same way that 45 ring gear teeth and 11 pinion teeth will give you 4.09s.
"The reason for the very slight differences in axle ratios like 4.10 and 4.11 is because of the slight ring gear diameter difference between the front and rear axles. It's just not cost effective for the gear manufacturers to try and make the ratio exactly the same since that slight .01 or so difference doesn't affect anything." does your ass hurt from pulling that out so fast? ![]()
85 W150, 94 YJ, 86 Bronco |
#7 (permalink) | |
Member # 9265
I DO NOT recommend trying this but.....
one day a buddy of mine and I went out wheeling. his toyota (81, SBC 350/TH350/203, 35" BFG's) had a 3.90 in the rear and a 4.10 in the front (only a temporary setup, for sure!) well needless to say, we hit pavement to go home, and his transfercase would not disengage! so we "unlocked" the hubs, assuming the problem solved. well his truck drove really crazy, pulled really hard and stuff. we couldnt figure out what it was. pulled the hubs off, and they were stuck locked! nothing broke, even after driving on pavement.
82 Toyota 4x4 LOCKED 94 Toyota Celica ST- daily driver; 98 Suburban 2500 6.5 TD- baby hauler |
#10 (permalink) | |
Member # 4783
#11 (permalink) | |
Member # 5516
#13 (permalink) | |
Member # 6234
RING GEAR DIAMETER DOES NOT EVER, EVER CHANGE (for a given axle type such as d44, 9", 14b, etc) got it? the only gear whose diameter ever changes is the pinion gear. the pinion gear size is only going to change a few thousandths of an inch anyway for a set of similiar gear ratios (e.g., 4.09, 4.10, 4.11) the "root cause" as you put it for the number of teeth on each gear is a manufacturer's whimsy. one day i could wake up and decide to produce 4.09s, the next day i might want to make 4.10s (that's simplified, but you get the idea). so don't got rollin those little pixelated eyeballs at me when you don't know what you're talkin bout, mkay?
#16 (permalink) | |
Member # 6234
gear ratio depends on the gear manufactuer. some will make 4.11s while other decide to make 4.10s. hell, i've even seen 4.08s for a ford 8.8 rearend.
#17 (permalink) |
Hillbilly Houndsman
Member # 13420
The ratio is the number of teeth on the ring gear divided by the number of teeth on the pinion gear.
Some have the exact same tooth count and one manf. will label as a 4.10 the other 4.11 The 2% rule is true. (Go measure your tire diameter from front to rear, there will be 1 tp 2% difference in those too)
The penalty for punching someone in the mouth is way too high in our society. www.MountaineerOffroad.com |
#19 (permalink) | |
Member # 5516
#20 (permalink) | |
90 4runner, v6, 5spd, toyota SAS, rear leaf swap, 5.29's, 38.5 boggers...95 Chevy 1500 350 4x4 |
#21 (permalink) | |
#23 (permalink) | |
Member # 6234
even if you are talking about different ring gear diameters between say a 9" and a d44, you can still get gear ratios with the same number of teeth. i guarantee you right now if you call randy's, northwestern, local 4x4 shop, whoever, that they can find you both a 4.11 and a 4.10 set of gears for both of those axles. i'm just gonna drop this now so i don't get worked up anymore. it's pointless to enter heated debate about something as simple as gear tooth count. i hope you understand what i'm saying, but if you don't, oh well. no hard feelings and to you all, just on general principle
#24 (permalink) | |
Wrong,A 4.09 would be the stronger gear set. In a ring and pinion set, the pinion gear is the weak point. The smaller the pinion, the weaker it is. The lower the gear set (numerically higher) the weaker the pinion. With fewer teeth, there also is less gear tooth contact, causing more stress on each tooth. Now this is really splitting hairs , but it is also more accurate than the previous statement.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night. |
