alignment
how to align a front end on a 84 jeep cj-7 ? thanks......................ltr
A Fatmans fitness blog |
Member # 2037
I just set the toe-in on my rigs. I use a tape and measure side wall to side wall both front and back. I set the front with a toe in of 1/8" to 1/4". It's always worked for me
Mark Langford KI6TMK '86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's Dysfunctional Rockcrawlers (TDO) |
thanks, I was thinking along the lines of what nut to turn where and what to adjust , thanks
Member # 2037
ummm, ok, here goes. The tie rod connects the drivers side steering knuckle to the passengers side knuckle. There is a large nut on each side where the tie rod end threads in. Loosen both nuts then turn the tie rod until you get the desired amount of toe in. You might have to use a pipe wrench to twist the rod. Make sure you tighten the nuts when you're done.
If you have a steering stabilizer that's attached to the tie rod, remove it before making any adjustments. Good luck!
thanks, that is what I was looking for...........ltr
Pathfinder
Member # 16125
Location: People's Republic of California, Southern Sector
my .02... spend $40 and have it done professionally before you ruin a couple of expensive tires.
Mark Matthews (The KOH guy, NOT the Pro Comp guy) 84 4Runner with lots of stuff All that is gold does not glitter, Not all those who wander are lost. |
I was hoping to correct it enough so I could go to the aliment shop but it after doing a little bit more reserch I plan on giving it a try worse comes to wore I can roll over to a aliment shop............ltr
