Getting a u-joint out - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-20-2003, 05:02 PM   #1 (permalink)
86Project's Avatar
Member # 6294
How do i do it without a vise. I don't have access to a vise readily and I don't want to pay someone. Got the clamps off and hit it with a BFH and a small socket but to no avail. Help me out guys, how do I get it off, a bigger FH? Let me know Please
02 Saleen Vert - Lots of shit done
92 4Runner, BJ's, LC springs, 285's, Man Hubs, Tons Planned
86Project is offline   Reply With Quote
Old 02-20-2003, 05:08 PM   #2 (permalink)
Pat
Pat's Avatar
Member # 120
If you don't have a vise or a press then it is up the the hammer to do the work for you.. Just be care full not to knick the flanges or ears ..
Try out a AppleSeed... http://www.appleseedinfo.org/
Pat is offline   Reply With Quote
Old 02-20-2003, 05:18 PM   #3 (permalink)
Does yer dewg bite?
vova's Avatar
Member # 196
http://www.pirate4x4.com/tech/ujoint_install/
It's under the tech section...
85' Toyota truck/runner. 60/14 bolt, 4.3L, 39.5's.
07' Turner RFX for exercise. (Ride hard or ride cross country)
In loving memory of Madelyn Rose Ekhilevsky
04/17/04 - 12/08/08
vova is offline   Reply With Quote
Old 02-20-2003, 05:24 PM   #4 (permalink)
86Project's Avatar
Member # 6294
thanks
i didn't see that under the search either
Old 02-20-2003, 06:53 PM   #5 (permalink)
Member # 11508
You could always get the cheap Harbor Freight 3 in one press. I think it's still on sale for $29. I got one for balljoint stuff, but it says it works on U-Joints as well. The tech link vova posted is very good as well. If you missed it, you didn't search right. But that's okay, you're still a newbie and you're in the right place.
ttabbal is offline   Reply With Quote
Old 02-20-2003, 10:37 PM   #6 (permalink)
Member # 16213
Sockets
I use sockets and a hammer to get them out.
Steps I take.
1. remove clips from ujoint
2. hold down driveshaft on concrete floor
3. find socket that is slightly smaller than ujoint cap.
4. tap, bang, and beat socket until the cap opposite of the one you're beating on starts to come out.
5. once cap is far enough out clamp it with visegrips and hit visegrips until cap is removed.
It's essential that the shaft does not move when you hit the cap. You can place socket on the floor and beat on the opposite side of the joint, it can get clumsy. Also, soak the joint with penetrating oil.
Don't give up, adapt and overcome.
Shizuka is offline   Reply With Quote
Old 02-20-2003, 10:46 PM   #7 (permalink)
AxlesUp's Avatar
Member # 1994
yea i live in an apartment complex and run into the same crap so i bought a tiger tool it is awesome. tiger tool has a web site that sells direct or u can get them from mike at complete offroad.
peace
Jw
AxlesUp@hotmail.com
AxlesUp is offline   Reply With Quote
Old 02-21-2003, 06:46 AM   #8 (permalink)
86Project's Avatar
Member # 6294
Thanks
Appreciate all the info I'll tear into it again tonight. Thanks again.
Old 02-21-2003, 08:55 AM   #9 (permalink)
Member # 5982
I've used the hammer, bj-press and shop press. The bj-press is by far the best.
I use a ball-pen hammer in the field. I always smack both sides with the rounded end of the hammer to break the caps loose if it is an old joint.
Was that a comment meant to hurt?
RU Dysfuncational http://thisdysfunctional.org/forum
jdjanda is offline   Reply With Quote
Old 02-21-2003, 01:20 PM   #10 (permalink)
Member # 12504
Send a message via AIM to Spank
Just get a bigger BFH. If they're the original joints, they'll probably be stubborn a hell anyway.
-Will
Spank is offline   Reply With Quote
Old 02-21-2003, 03:55 PM   #11 (permalink)
Rapey
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
I use a large bolt and a hammer. No sense in beating up a socket. It helps if you have a table with a hole in it.
Think you're a marksman? Test your skills by joining the 200yd Iron Sight Challenge happening NOW in the OSR Forum:
http://www.pirate4x4.com/forum/outdo...-may-31-a.html
animator is online now   Reply With Quote
Old 02-21-2003, 07:32 PM   #12 (permalink)
Member # 7340
Make sure that the clips are actually removed.. Some have inner clips, some have outer, and some have both..
Then of course there is the melter plastic crap
Put some heat to it, it will go...
[COLOR=BLACK] You picked a fine time to leave me loose wheel [/COLOR]
Chad H is offline   Reply With Quote
Old 02-22-2003, 01:59 PM   #13 (permalink)
Member # 5306
Send a message via AIM to reddwarf Send a message via Yahoo to reddwarf
Both? Never seen that...do you know of a specific application?
"I'm ridin like a felon" -- Doug
reddwarf is offline   Reply With Quote
Old 02-22-2003, 03:18 PM   #14 (permalink)
Philabuster's Avatar
Member # 13350
Re: Getting a u-joint out
I've done it with a BFH and two small 2x4's (standing up on the long side) in a friends driveway a few times. It works, but not as easy as a good vise.
Phil
2001 CTD 2500 QCSB 6SP 4X4
1980 Turbo Diesel Scout II
Philabuster is offline   Reply With Quote
Old 02-22-2003, 03:22 PM   #15 (permalink)
Hillbilly's Avatar
Member # 857
I was taught to use a C clamp before I bought a vise. A BFH works just aswell.
Hillbilly is offline   Reply With Quote
Old 02-24-2003, 04:31 AM   #16 (permalink)
86Project's Avatar
Member # 6294
Damn that was easy
I really appreciate all the help and info, made what seemed like a scary job really freakin easy. Thanks again did it with a BFH and a socket didn't have a vise or c clamps or a good set of pliers so I just beat it till it came all the way through one side pulled the cap off and leaned it out the front side. Really, Really easy took less than ten minutes for both U-joints. thanks Knowledge is power
Old 02-24-2003, 07:07 AM   #17 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
I actuially just learned how to pull those this weekend. I have a big vice, but fatkid showed me the hammer and sockets way since we won't have the vice on the trail
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 02-24-2003, 08:33 AM   #18 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I know the hammer and socket method well. I helped a buddy
change out the rear driveshaft u-joint on his daughters Heep on
the side of the highway a few months back on the way to the
desert. 45 mins start to finish.
SanDiegoCJ is offline   Reply With Quote
Old 02-24-2003, 11:45 AM   #19 (permalink)
Imkunfused's Avatar
Member # 2804
Send a message via AIM to Imkunfused Send a message via Yahoo to Imkunfused
Actually if you do it right, and the caps arent rusted in.. all you need is a hammer, and you dont even have to hit the ujoint
A conscience is what hurts when all your other parts feel so good
Imkunfused is offline   Reply With Quote
Old 02-24-2003, 07:16 PM   #20 (permalink)
Member # 8679
Send a message via Yahoo to shaggyzukin
I have a vice in my Jeep. Soon it will be attatched to a plate welded to some square tubing that will fit into my reciever hitch.
Seems easy enough.
Shaggy
1987 Zuki, webber, 31's.
1988 XJ, parting out
SWJA Tresurer
shaggyzukin is offline   Reply With Quote
Old 02-25-2003, 07:17 AM   #21 (permalink)
Member # 9245
If thay are orginal heat it up untill black shit shoot out and that hit it with a BFH[SIZE=3]
sleslie is offline   Reply With Quote
