2" Budget lifts - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-26-2003, 10:21 PM   #1 (permalink)
Member # 17392
2" Budget lifts
I have a 96 XJ with upCountry package. I wanted to do a budget lift on it. Rocky Mountain Outfitters has a 2" kit, using 1.5" shackles and 1/2" spacer in the rear, and 2" poly spacers up front.
My questions are:
Will this affect my driveline, i.e. will it vibrate and need shim/adjustments?
Will I need different shocks due to the longer reach required?
(I am currently using RS9000 (9129s) in the rear, stock up front)
Do I need a 4 wheel alignment when it's all done?
Any help would be much appreciated.
Thanks!
'OG'
oogee is offline   Reply With Quote
Old 02-27-2003, 04:36 AM   #2 (permalink)
Member # 15612
Actually the correct answer is it belongs here: PBB Newbie General 4x4 discussion
but to answer:
It's very unlikely that it will afftect your driveline
You don't NEED different shocks.
No such thing as a 4 wheel alignment on a Jeep, nothing to adjust in the back. The front will need a toe-in adjustment which takes 5 minutes with a tape measure and pipe wrench. It's unlikely that 2" will noticably affect your caster
Just
Excreted
Eaten
Peanuts
[quote]
How tall exactly do I have to make the spacer to get 2" of lift out of it?
[/quote]
XJ Sean is offline   Reply With Quote
Old 02-27-2003, 09:45 AM   #3 (permalink)
james west's Avatar
Member # 7224
i thought thats where we were?
i got nothing
james west is offline   Reply With Quote
Old 02-27-2003, 09:57 AM   #4 (permalink)
Member # 15612
It was moved here from Jeep tech
(my response made more sense before the flame posts were emoved)
Just
Excreted
Eaten
Peanuts
[quote]
[/quote]
Old 02-27-2003, 01:24 PM   #5 (permalink)
Member # 11322
my brother runs about 3" lift on his. he has no driveline problems. it has been on for about 6years now. you probably will need longer shocks. shops always recommend alighnment after lifting. you could probably get by without it.
resqdvr90 is offline   Reply With Quote
Old 02-27-2003, 01:45 PM   #6 (permalink)
Member # 17174
Send a message via ICQ to Krawwler
i haven't heard anyone complain about driveline probs with a 2", you should be o.k.
Krawwler is offline   Reply With Quote
