The Torque Flite 999 is a medium duty Chrysler 3 speed automatic transmissions. They have an aluminum case and a 23 spline output shaft. The case is ??" long and ?? bolts hold in the pan.
Modern versions are still use the 23 spline output, but engine bolt patterns have changed and the newer ones have electronic shift control. I have conflicting information about torque converters. Some say early models did not have a lock up torque converter and some say they did. Newer models have a lock up torque converter. Usage The TF 999 was used in CJs from 1980-1986 only with the I6 and V8 engine. It was also used in 1984-1990 SJs and J pickups with the 4.2L engine, in the YJ from 1987-1991 with the 2.5L and 4.2L engine, and in the XJ in 1991 with the 2.5L engine. A modern version of the 999 continues to be used in Wrangler YJs and TJs to this day with the I6 engine. Transmission 1st 2nd 3rd 4th 5th Rev TF 999 2.74 1.55 1.00 2.20
It was even more of a turn on when I found out she was doing me to buy baby formula |
Doesn't look like it.
The AW4 is a 4 speed automatic overdrive transmission. Usage The AW4 four speed automatic transmission was used in 1987 to 1990 Jeep Cherokee (XJ), & Jeep Comanche with 2.5L & 4.0L engines. The AW4 was also used in 1991 through 1992 Jeep Comanche & 1991 through 1998 Jeep Cherokee & 1993 through 1993.5 Jeep Grand Cherokee with 4.0L engines.
I figured the overdrive might be an issue. Can the 999 go in as a replacement without issue?
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL] [/SIZE][/CENTER] |
What about this. Lets say I have an 88 YJ 999/231 setup bolted together. I just need to know if I can pull the XJ setup from bellhousing back and toss in the YJ stuff without any mods (cept driveshaft). I know the computers in XJ 4.0 are different, would the system revolt the 999?
#9 (permalink) | |
Member # 10655
The 999 was also used behind the 84-86 XJ-chevy powered 2.8L v6s and also has the lock up torque converter. They also have the unique 60 deg v6 bell housing. (my converter locks up at 40 mph, and kicks back out at 35 mph) Just useless info to dabble in, but shares many of the internal parts.
"just another day at work" '65 CJ5A, 88 K2500 tow rig, 68 C10 300HP L30 327, |
Mr. FixIt
Member # 5295
I should work out for you. I am using a 91 XJ engine (was mated to an auto), harness and computer in my '88 YJ w/ a 5 spd. The engine computer does not care that all of the auto wires are disco'ed. You will probably need to just ground out the Neutral/Park switch on your XJ harness. I have an FSM from a '91 if you need pin numbers and wire colors. They will probably be different though becuase your XJ has the Renix FI in it.
'88 YJ with not much '88 YJ left We-Rock Stock Class Team Mall Crawler #609 Sponsored by: The Drive Shaft Shop www.driveshaftshop.com Delaware Jeep Assoc. www.delawareja.com |
#12 (permalink) |
another dunb newbie
On this same note I have a 1985 jeep waggy with a 999 torque flight in it will that set-up bolt in a 90 yj with 2.5L? also its an amc 360 in the wag with what I think is a 241 t-case.
any help for this newbie?
I swear to god ask Donna! helmethead is an awsome dentist! |
#14 (permalink) | |
![]() I know worst case I can get one for $400. But the more I look into this it kinda sounds like a bad torque converter
#17 (permalink) |
Obtuse
Member # 15436
Dunno if you are having the same AW4 issues I am (in my 89 4.0l XJ)...but my torque convertor quit locking up after I swapped out the master cyl and power booster. I must have narfed the switch (that unlocks the TC when brakes are applied) somehow during the swap.
Friday at lunch I made the rounds - Advance & the Zone don't list it, the Jeep Stealership wanted $40 and a week to order it...I may check NAPA tomorrow, I have heard it's about $12 there. Anyway here is a link for some cheap mods that allow full manual control over the tranny by 'outsmarting' the Tranny computer (TCU) I plan to try this one day this week at work (it's nice to have a 'wheelin' boss) and if it bypasses the lockup switch, my life will be nearly complete & I won't have to pull the seat out and climb under there no mo! http://www.bigoffroad.com/pages/bigp...ch/2ndgear.htm |
#18 (permalink) | |
HeiserOilMotorsports
Scott
#19 (permalink) |
I bought a samurai instead
I didnt wanna get into another "project" vehicle as a daily for my wife.....so she got this ![]() http://www.rps4wd.com/cgi-bin/yabb/Y...num=1047265339
