Auto Trans Cooler Question - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-05-2003, 06:29 AM   #1 (permalink)
Member # 8766
I'm getting ready to put on an Aux Trans Cooler on my 91 Toy 4runner. My questions are:
1) Should I run dual line ones to the rad and ones to the new cooler?
2) If I run only to the new cooler what do I do with the line holes coming out of the rad?
3) Should I just replace the trans cooler that is there but is very small back by the Transfer case?
Why work go wheel'n
edwardsteiger is offline   Reply With Quote
Old 03-05-2003, 08:44 AM   #2 (permalink)
Member # 11508
Re: Auto Trans Cooler Question
You can keep the one in the rad if you want, it doesn't make that much difference.
Plug them.
Does the rear one have any airflow? If the new one has a fan, you could do that. Or just put the cooler in front of the rad.
ttabbal is offline   Reply With Quote
Old 03-05-2003, 04:08 PM   #3 (permalink)
Newbie
JimD's Avatar
Member # 4923
Send a message via Yahoo to JimD
I used the cooler in the radiator, I cut into the line coming out of the radiator to the aux cooler infront of the radiator and back to the tranny. Make sure you run through the aux cooler after the radiator.
JimD is offline   Reply With Quote
Old 03-05-2003, 04:52 PM   #4 (permalink)
Member # 5021
Bypass the radiator all together. Run the largest cooler you can fit/afford.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 03-05-2003, 09:12 PM   #5 (permalink)
Member # 4225
Send a message via AIM to pavelow
Thats what I did. I am using a cooler that is for a mobile home, keeps that thing plenty cool. It takes up half of my radiator. You can get them pretty cheap at autozone too.
Wanna touch it?
pavelow is offline   Reply With Quote
Old 03-05-2003, 09:13 PM   #6 (permalink)
HeiserOilMotorsports
Po' riggity's Avatar
Member # 1515
Send a message via AIM to Po' riggity Send a message via Yahoo to Po' riggity
I run both the radiator cooler and aux cooler and it works well. Ive got a perma cool cooler, and I have to say it works really well!
Scott
HeiserOil Motorsports:
Crawlin' For Crohn's
Friends of San Bernardino National Forest (website not yet complete),
brought to you by Sbwinvps
Originally Posted by Alpine4x4 View Post
y'all know my flatbill hats make me the best desert racer out there!
Po' riggity is offline   Reply With Quote
Old 03-06-2003, 12:00 AM   #7 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
I by passed my stock cooler, and just ran an aftermarket one. Every hill it hit i was getting darn close to over heating my transmission, so i added a second cooler. Problem gone.
http://store.summitracing.com/partdetail.asp?part=12237
Without the gague i would never have known my tranny was overheating until it was too late... or i can just take the advise of my ex-tranny guy who told me dont put in a gague, because it is just one more thing to leak, and you will know if the trans is over heating if trans fluid comes out of the over flow.
Lets just say i grabbed my keys and havent been back since...
No wonder it took him 2 months, and numerous times to rebuild my tranny.. only to just put in a mopar rebuilt one. And i thought 35 years in the tranny businees ment something
Garrett
GRMhick is offline   Reply With Quote
Old 03-06-2003, 04:50 AM   #8 (permalink)
El Guapo
TexasBlake's Avatar
Member # 9722
Where did you mount the guage? Did you just tap a mechanical guage in the pan, or did you put it in line somewhere?
TexasBlake is offline   Reply With Quote
Old 03-06-2003, 04:55 AM   #9 (permalink)
Member # 8766
Thanks for the input. I think I'm going to run the in line to the rad and the output to the aux cooler put it in front of the rad and the run the output from the cooler to the trans. Hopefully this will keep it cool.
Why work go wheel'n
Old 03-06-2003, 09:33 AM   #10 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
This is the way to do it, If you live in a Cold area, The Radiator cooler helps heat up the Tranny Fluid as well, To cold os Tranny fluid = crappy
Mark
welndmn is offline   Reply With Quote
Old 03-18-2003, 10:19 PM   #11 (permalink)
Member # 14600
If you live in a cold climate you might want to keep the radiator cooler hooked up also, too cold a fluid is just as damaging to an auto trans.
Oatmeal is offline   Reply With Quote
Old 03-19-2003, 12:05 PM   #12 (permalink)
Supergper's Avatar
Member # 2159
Send a message via ICQ to Supergper Send a message via AIM to Supergper Send a message via MSN to Supergper Send a message via Yahoo to Supergper
TCI recommends not to use the radiator cooler...I didn't read why but go to their site and read the FAQs www.tciauto.com
-Caleb Call
Supergper is offline   Reply With Quote
