Member # 1924
'03 Jeep lifts recommendations
My brother from years with a 72 Bronco finally bought an 03 Jeep. He is looking at lifting it. I am recommending going with a Rubicon Ex. 4.5 or a teraflex. But if he chooses, due to cost, to buy a less expensive like the SkyJacker 4" with lower control arms and the transfer case drop stuff. Will he have driveshaft vibration problems or does the transfer case drop help with this. The RE stuff recommends the slip yoke elim. and CV rear shaft. What are your recommendations for him?
Thanks.
1969 Toyota Fj40, 5.3 Chevy Vortec, NV4500, Fzj80 axles. [url]http://www.toysandbox.com[/url] |
Member # 17311
The t-case helps with this but evey vehicle is different so I can't tell you if you are going to need a SYE and CV. just going to have to go for it and find out. I would suggest against a t case drop cause it reduces ground clearance which is what you are trying to improve...
Q
Nex Pro Evinco "Death Before Defeat" |
