Member # 7938
I need some ideas for floor covering in my Toyota. What have you used or would like to use. I want some type of insulation or pad and then a covering that is rubber or something along the line of the factory pad. Oh, and I do not want to spend the $ for the spray in bed linner.
I make websites!
Did you use the 3M stuff or the no-name brand?
I bot 2 spray cans one 3M and one no-name.. 3m was thicker but your right smell is nasty! I wouldn't call it cheap there like $5.50 a can.... Buddha- I was going to use the spray stuff for my jeep but was afraid of it heeting up in summer and turning all gooy... |
#5 (permalink) | |
Member # 7938
Member # 10314
This stuff is the shit. I’ve seen a couple of jeeps that my buddy painted and used this stuff on the inside of the tubs. Easy to apply and it’s tintable. It took one kit to do a nice thick coat on the inside of a Jeep tub.
http://www.eastwoodco.com/aspfiles/i...1.x=46&I1.y=54
There's nothing stopping you but fear and common sense. |
Member # 17040
I used ZEP brand professional rubberized coating, it says that it can be used on hoods and firewalls for sound dampning so I assume that heat wont turn it to NASTY GOO. I just did it about 3 weeks ago and so far so good, I did notice that when my transmission gets warm it softens a little, but over time it seems to cure more(getting harder) but ill see this summer
#10 (permalink) | |
IH/Rover Moderator
I like beer. On occasion, I will even drink beer to celebrate a major event such as the fall of communism or the fact that the refrigerator is still working." BUY MY BOAT http://www.pirate4x4.com/forum/misc-...e-history.html |
#12 (permalink) | |
IH/Rover Moderator
I used it in my doors as sound deadener. Everything was fine until six months later in mid August when we had a heat wave. The crap was dripping out of the drain holes in the door. It covered the door sill and made a mess of the carpet. Problem #2 was three months later when the door filled full of water from the plugged drain holes. I spoke with the lab and they said it was just roofing tar, same chit can be bought from Home Depot in the roofing dept. ZEP sucks!
#13 (permalink) |
Member # 17040
thanks for the info oldscout, that looks to be the same crap except mine has a chinaman on the can
well shoulda asked around first before i trusted a can of goo.....will see what happens this summer
#14 (permalink) | |
Member # 9265
82 Toyota 4x4 LOCKED 94 Toyota Celica ST- daily driver; 98 Suburban 2500 6.5 TD- baby hauler |
#15 (permalink) | |
I see you're from walnut creek, what do you drive? (wheeling wise) |
#16 (permalink) |
Member # 17040
1982 toyota pickup with hopes of modifications soon.
HEY OLDSCOUT what do you think about sealing this ZEP shit with spray paint? any thoughts or should i put the carpet back in and forget about it?
