Ford HP Dana 44 ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-08-2013, 10:59 AM   #1 (permalink)
Member # 68964
Ford HP Dana 44 ???
Just picked up a HP Dana 44 from a 76 ford f 100. Planing on putting it under my 89 yj SOA Ford 8.8 rear. Want to keep the ford lug pattern. Just want to get every ones opinion on what parts to mix and match ro make it happen. Any other problems i might run into doing this swap?
Beerguzzler is offline   Reply With Quote Quick reply to this message
Old 04-08-2013, 11:02 AM   #2 (permalink)
Member # 197879
Yukon super 8.8 kit if it's an explorer rear.
Ranger Build~
brinker88 is offline   Reply With Quote Quick reply to this message
Old 04-08-2013, 06:36 PM   #3 (permalink)
Member # 92402
Might want to check the year on that d44. If I remember right, 76' ford d44 were not high pinion. The d44hp started in 78'.
Tellico online rally post #690.
04'Rubi,tons,leafs,38's/99'TJ,stock
Jeep74j20 is offline   Reply With Quote Quick reply to this message
Old 04-08-2013, 07:01 PM   #4 (permalink)
Member # 133589
Half tons were all HP
I hate everybody, don't it feel great.......... to hate?
mvanhelden is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 05:13 AM   #5 (permalink)
Member # 46175
You didn't actually mention it, but I am assuming your 8.8 is an explorer rear end with 5 on 4.5"?
What was your plan to overcome the width difference between the D44 front and an Explorer 8.8 (if that is what you have)?
I believe '76 F100 is still the undesirable passenger axle tube configuration. IIRC, 75 and down were the welded on wedges for the radius arms w/ one piece tube on passenger side. Which is why almost every TJ HP 44 I have made started as the 78-9 F-250 front end.
Clayton's brackets are really nice when you are shopping for those.
USED and NEW 4x4 PARTS - (716) 984-8715 8-5pm EST
Specializing in Axles and Transfercases
Mh4Runner is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 06:32 AM   #6 (permalink)
Member # 200826
^x2, unless you use an 80-96 bronco/f150 8.8 I believe you have yourself a 5x5.5 front 5x4.5 rear (if explorer rear)
95 ish f150, 1 tons, 42's
rclark12 is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 06:47 AM   #7 (permalink)
Member # 226215
I've seen 78 welded on f100 brackets. You really have to look close usually taking the springs off and scraping the dirt away to see what type of wedge is under the spring mount.
But not really.
Nixer600 is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 06:47 AM   #8 (permalink)
Member # 197879
Which would require custom axles such as Duchman Alloys or Super 8.8 semi-float kit to match bolt patterns...
Ranger Build~
Old 04-09-2013, 06:48 AM   #9 (permalink)
Disc brake guru
GubNi's Avatar
Member # 25927
Get the rear axle from the same truck and go for it.
Dana 60 or 14 bolt disk brake kits $315 shipped -->
Dana 70 kits $300 -->
. . Sterling 10.25 kits $390 -->
Dana 60 front 3/4 ton kits $295-->
GubNi is offline   Reply With Quote Quick reply to this message
Old 04-09-2013, 08:36 AM   #10 (permalink)
Member # 68964
44 is HP and does have weld on mounts. As for the bolt patter prob just gonna get some wheel spacers that adapt it to the 5 on 5.5 to match front
Old 04-09-2013, 12:44 PM   #11 (permalink)
Member # 109963
Or get an f150 8.8 and swap your parts over
caseyray63 is offline   Reply With Quote Quick reply to this message
