yoke ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-05-2003, 09:33 PM   #1 (permalink)
misfitcj's Avatar
Member # 11829
Send a message via MSN to misfitcj
yoke ???
allright the rear shaft on my heep needs to be replaced........I need to put on a new out put yoke on my dana 300 and input for my rear end an amc 20 ( I think that is the term ) any ways if I undo the nut that holds them on . Am I going need to do anything more than screw it back on to the right tork on ethier end, or is there more to it if so please explain .........................ltr
A Fatmans fitness blog
misfitcj is offline   Reply With Quote
Old 05-06-2003, 03:12 PM   #2 (permalink)
misfitcj's Avatar
Member # 11829
btt
Old 05-06-2003, 03:48 PM   #3 (permalink)
Member # 17152
Before you pull the yokes, put on a torque wrench and check the torque, especially the M20. The M20 has a crush collar, so don't over torque it, or you'll need to pull it apart and replace it. It also might be a good idea to replace the pinion seal on the axle while you have the yoke off. Its pretty cheap at the parts store and just one of those preventive maintance things to do while you're under the rig. Oh yeah, I hope you're putting u-bolt style yokes on it, the straps are just a waist of time. Any spicer dealer can hook you up w/ the right parts. Good luck.
blacklabjeep is offline   Reply With Quote
Old 05-06-2003, 05:16 PM   #4 (permalink)
misfitcj's Avatar
Member # 11829
thanks that is exactly what I am doin ubolts swap......................ltr
