How to ID if rear diff is limited slip???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-26-2003, 08:39 AM   #1 (permalink)
Member # 19901
I am going to change the fluid on my 95 YJ 4-cyl. How can I tell if the rear diff is L/S and needs friction modifier?
I dont see any tags on the case, how about the bolt pattern or ??????
Thanks!
BrandonV is offline   Reply With Quote
Old 05-26-2003, 08:51 AM   #2 (permalink)
Member # 10416
LS cases are more "square", while open cases have a slight curve inwards when going away from the ring gear. So if you're looking at your diff, look from the ring gear to the right. Does the case curve or is it straight?
[URL=http://www.longhornoffroad.com/]Longhorn Offroad[/URL]
76/79 scout II, one ton axles on the way!!!
"Some people spend thousands on psychiatrists, I beat shit with a hammer" --Jesse James' Monster Garage
[QUOTE][i]Originally posted by Overbear [/i]
[B]2) I think we can all say doug is clearly a darwin award canadate. Let us all hope he gets his place in them soon before he reproduces.[/B][/QUOTE]
TxScout is offline   Reply With Quote
Old 05-26-2003, 09:16 AM   #3 (permalink)
Member # 19901
Thanks for the reply.
I'm having doubts about what I think it is, could you take a look at these pics I took and tell me if you can tell for sure?
I dont want screw this thing up.
http://www.ofoto.com/BrowsePhotos.js...4159803&page=1
click on thumbnail for larger view.
Old 05-26-2003, 09:37 AM   #4 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
You have to remove the cover to see the carrier. No real way to tell untill you do. I'm pretty sure that 4 bangers didnt have a limited slip as an option.
I'm the "tack tack tack" welding nazi.
http://www.pirate4x4.com/forum/showp...&postcount=218
"I didn't mean to kill nobody ... I just meant to shoot the sonofabitch in the head. Him dying was between him and the Lord." R. L. Burnside
kwrangln is offline   Reply With Quote
Old 05-26-2003, 09:44 AM   #5 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
An open differential will look like this.
Old 05-26-2003, 09:49 AM   #6 (permalink)
Member # 19901
Ah crap!
I dont have time to do that, I need to use it today and dont have time to let a silcone gasket cure. There's no way to tell from jacking it up and spinning the tire?
BTW, last winter I noticed that going uphill only one tire would get power and it never transferred power to more than one rear wheel in 2WD.
I dont think it has it either but I dont want to burn the clutches if it does.
Thanks for your help!
Old 05-26-2003, 09:55 AM   #7 (permalink)
Doublewide engineer
kwrangln's Avatar
Member # 6971
If it has a limited slip, its a tracklock, commonly refered to as a trashlock. It doesnt take many miles to turn this limited slip into an unlimited slip. I wouldnt worry about it. How the hell are ya draining the fluid to change it if your not pulling the cover off? Pumping it out? Its always a good idea to pull the cover to see what kind of crap you have floating around in there, especially with the dana 35 rear end.
If your really worried about it then go ahead and put the modifier in, it wont hurt anything if you do have a standard open diff.
Old 05-26-2003, 11:11 AM   #8 (permalink)
goatman21's Avatar
Member # 19839
Send a message via AIM to goatman21
Even if it is an open diff it will not hurt anything if you put the additive in it. If you're not sure, go ahead and put it in just to be safe.
goatman21 is offline   Reply With Quote
Old 05-26-2003, 09:16 PM   #9 (permalink)
nathon001's Avatar
Member # 18209
I have a factory "Trashlock" in a ff d60. When both tires are off the ground spend the wheels. If the tires spin in that same direction you have a limited slip. If they turn in opposite directions you have an open dif.
nathon001 is offline   Reply With Quote
Old 05-27-2003, 07:34 AM   #10 (permalink)
Hillbilly Houndsman
SilverZuk's Avatar
Member # 13420
This guy has the answer!
You jack up both wheels, and spin one with your hand.
If they both spin the same direction it has some sort of traction aid (limited slip, locker, etc.)
If the tires spin opposite directions, it’s an open dif.
The penalty for punching someone in the mouth is way too high in our society.
www.MountaineerOffroad.com
SilverZuk is offline   Reply With Quote
Old 05-27-2003, 05:36 PM   #11 (permalink)
Moderator
apeters89's Avatar
Member # 7647
Just make sure you leave your tranny in neutral when doing this. Otherwise you won't be able to tell.
Check out our new Team Ape Eater Racing Like us on FaceBook
KF5EQF
Sniper Fab
4x4Oil SBwinVPS Custom Splice C2GFab
apeters89 is offline   Reply With Quote
Old 05-27-2003, 10:55 PM   #12 (permalink)
Member # 3132
just put 1 side of the axle on a jack stand and try to drive off it in 2wd. if it pulls it's got a ls. god it's hard to type while holding a 6 month old
NOODLES is offline   Reply With Quote
Old 05-28-2003, 07:22 AM   #13 (permalink)
P&T Jeeps's Avatar
Member # 3916
BTW, the silcone needs maybe 2 minutes to cure, if that. slap on the goo, bolt it up, and fill away....
TJ; ARB'd & ChroMo'd 1-tons; 42" IROK's; Atlas 4.3; 4-linked, 106" WB...
The Build
P&T Jeeps is offline   Reply With Quote
Old 05-28-2003, 07:53 AM   #14 (permalink)
nathon001's Avatar
Member # 18209
AMEN brother!! Mine is six months old today. Does your six month old start pounding on the keyboard if you blink to long?
Old 05-28-2003, 03:45 PM   #15 (permalink)
Member # 3132
don't get me started.
