Moderator
pinion yoke
I bought another D35 axle last night (I know, I know, but I had to get my daily drive back on the road immediately) because the ring & pinion weren't set up properly (it's cheaper to get a whole new housing than to get gears set-up). Anyway, the yoke that is on this new axle is not the factory one. The yoke is larger than the original. I need to swap my original yoke onto this new axle, and I wanted to know if there was anything special I needed to do to swap the original one back on there. Do I just tighten it down as tight as I can with a little bit of lock-tite in there to keep it from loosening up?
Check out our new Team Ape Eater Racing Like us on FaceBook KF5EQF Sniper Fab 4x4Oil SBwinVPS Custom Splice C2GFab Last edited by apeters89; 06-06-2003 at 03:01 PM. |
Member # 16812
Is there no castleated nut? Or any provision for a pin at all? How about a positive locking washer? (something with fold-over flaps, not just the split ring or internal/external star washers)
That thing spings pretty fast with a fair amount of torque. It might cause some problems if it backs off.. I'd want a little more assurance than my impact gun can give. Just a thought. -tom |
Member # 7066
Use an impact gun and remove it. Spin it on the same way...There is likely to be a flat washer under there in all the gook. The nut itself is normally tweaked a little to keep it from backing off. This is a special nut similar to rocker/valve nuts. I don't know the technical term.
Just put it back on tight and it shouldn't be a problem.
Four Dice 4Wheel Drive Club. San Jose,CA 53 M38A1 60's F&R Atlas/SM420/350tbi project/F250 superduty www.fourdice4x4.bizhosting.com |
