how to rotate mud tires? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-06-2003, 04:52 PM   #1 (permalink)
Member # 20073
Send a message via AIM to norcaldude
is there any specific way i should rotate my radial tsl's? what tire should go where? does it matter? thanks
norcaldude is offline   Reply With Quote Quick reply to this message
Old 06-06-2003, 04:54 PM   #2 (permalink)
Member # 16812
The tires rotate every time you drive it..
Sorry.. It's Friday! I have nothing to add.
-tom
LandCroozer is offline   Reply With Quote Quick reply to this message
Old 06-06-2003, 05:13 PM   #3 (permalink)
Member # 2242
Since they are radials and non-directional you can rotate them across the vehicle (passenger rear to driver front, etc).
Harry Wagner
Freelance 4WD Writing & Photography
Vehicle Features, Tech, & Trail Reports
Dirty Harry is offline   Reply With Quote Quick reply to this message
Old 06-06-2003, 10:58 PM   #4 (permalink)
Member # 14778
I've always gone front to back and back to front.... keeping tires on same side of rig too. Makes it easy to remember which tire goes where
Toyofast is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 11:40 AM   #5 (permalink)
Member # 4321
Send a message via ICQ to DEnd Send a message via AIM to DEnd Send a message via MSN to DEnd Send a message via Yahoo to DEnd
on a RWD vehicle the proper rotation is to cross the fronts to the back (putting the front tires on the opposite side at the rear) and move the rears to the front keeping them on the same side. This is also the proper rotation on a FWD or AWD vehicle with even tread wear.
Lame Sig Line
DEnd is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 02:16 PM   #6 (permalink)
Member # 13942
I rotate my 35's every time I do an oil change, 3000 miles. They are on my daily driver and they have lasted almost 4 years. I rotated them the way DEnd did...
J. Schubert is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 04:58 PM   #7 (permalink)
pirate's Avatar
Member # 19860
Ditto!
pirate is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 08:36 PM   #8 (permalink)
Pick's Avatar
Member # 19983
From the Interco website:
3) Rotate the tires front to back and back to front about every four to six thousand miles...do not criss-cross...keep the tires on the same side of the vehicle. This practice will help to even out the uneven wear that often shows up on the front tires' outer lugs from hard cornering or a lot of in-town driving. HTH
Pick
Pick is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 10:07 PM   #9 (permalink)
Member # 11975
Send a message via AIM to MikeW Send a message via MSN to MikeW Send a message via Yahoo to MikeW
I would mark them with chalk, like FR, FL, RR, RL. So you know which ones were where especially if you have two sets of tires like I do.
MikeW is offline   Reply With Quote Quick reply to this message
Old 06-07-2003, 11:24 PM   #10 (permalink)
3d Artist for Hire!
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
Did mine the same. When I bought a new truck that came with AT's, I didn't rotate them as much, and there was a noticeable difference in wear, granted that's comparing a mud terrain to an all terrain, but had I rotated them more often, they would have lasted much longer.
Sometimes I parkerize stuff. PM for info..
animator is offline   Reply With Quote Quick reply to this message
