Member # 19928
About a month ago I went over these harsh speed bumps while going to a buddies and one of them blends right in. I was going about 15 mph (give or take) when I hit it. After-word my truck vibrated like a mother. I could not locate the problem, and after about a month it went away and was running smoothly. Well today I did it again (Im so stupid ) and now its started again. What is causing this??? I cant stand it!!! The vibration comes up in the steering wheel and the dash vibrates badly. You can also feel it in the floor. If it helps my truck is and 83 yota.
Thanks For Any Help
Just Gettin Started |
Have you checked for anything loose in the nose? If you can feel it in your steeering wheel, its in the nose....
Why is it we all are for doing the same thing--but yet we can not work together to achieve it Mike Crash Kash The new live streaming video crashfab |
Member # 5776
What crash said. Easiest way to spot it is to have someone turn steering back and forth while you look for something loose. This is possible "DEATH WOBBLE" by the way. Search on that and you'll find more than you can stand to read as far as info and solutions.
[size=1]ASE Certified Master Automotive Technician Toyota Certified Expert Technician Volvo Certified Expert Technician Suzuki Certified Master Technician IDPA Certified Master Cardboard Killer[/size] |
Member # 19928
Im running 31 bfg a/t ko's. Well It went away today after going down a very bumpy dirt road. It's running really smoothly now. Very Strange.....
Member # 15005
I would suspect a motor mount that is at least partially damaged. Could be the impact pushes it out and over time it settles back into place. The motor shifting would take your transmission out of alignment and cause vibrations. Take a good look at the mounts and maybe check to see if the fan has touched the shroud. That is usually a dead giveaway that the engine has shifted.
Cuz were in the spirit world, asshole, they can't see us. |
Member # 12695
Seriously, you need to jack the vehicle up (take the weight off the wheels) and check it out. Before someone gets hurt or broke down.
Dan
"We live in the Land of the Free because of the brave." Please remember our Troops! |
