10 bolt to 12 bolt? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-24-2003, 10:45 AM   #1 (permalink)
Member # 8174
Send a message via MSN to Bill4rest
10 bolt to 12 bolt?
I was wondering if there was a difference in a 73 12-bolt width and an 87 10-bolt width? I'm also assuming that a 12-bolt would be stronger in a towing application? Any help would be great.
Bill4rest is offline   Reply With Quote
Old 06-24-2003, 01:29 PM   #2 (permalink)
44Runner's Avatar
Member # 9095
Send a message via AIM to 44Runner
Re: 10 bolt to 12 bolt?
Can't help you with the width, but the 12 bolt is definately stronger than the 10. Go with a 14 and don't look back
Buggy in progress - 22RE on pane, A340, 4.7:1, 8" f/r, 4Ds
Project Straight Pimpin' - 1989 4Runner 3.slow 5spd SAS'd 8" F&R w/4.30 255/85R16
2005 Ram 2500 4x4 CTD 6spd QC SWB
44Runner is offline   Reply With Quote
Old 06-24-2003, 02:32 PM   #3 (permalink)
Banned
Member # 11585
if a 12 bolt is any stronger, it is minimal.
Two Dogs F..king is offline   Reply With Quote
Old 06-24-2003, 04:18 PM   #4 (permalink)
DSI
DSI's Avatar
Member # 920
Send a message via Yahoo to DSI
28sp vs 30sp
8.5rg vs 8.875rg
noticable bearing size difference...
naa not to much...
seriously though bill... chevy trucks from 73-87 all look really similar 1980 was the year they changed the grille, and sharpened a few lines up, but were basically the same truck, that 12blt should be the same width or within a 1/2in
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports
DSI is offline   Reply With Quote
Old 06-24-2003, 04:24 PM   #5 (permalink)
Member # 8174
Thanks I have it in the garage and it already has 4.10's in it so Thats that I suppose, Thanks guy's
Old 06-25-2003, 07:39 PM   #6 (permalink)
Member # 2095
Originally posted by DSI
28sp vs 30sp
Didn't the 10 bolt get 30 spline some time in the '80's?
'79CJ5,soa,d44/60,t18,d18w/Obrian 3.6low,5.13's,35x14.5SSR's
'02 Z71
CJ-Jeeper is offline   Reply With Quote
Old 06-25-2003, 09:24 PM   #7 (permalink)
Member # 17238
Send a message via AIM to dustytool
think so
It's a [b]MELISSA JOAN HART[/b] thing you just wouldn't understand!
dustytool is offline   Reply With Quote
Old 06-25-2003, 10:43 PM   #8 (permalink)
Member # 10736
I believe the 10 bolt got 30 spline shafts at one point. If it is a question of upgrading to a bigger axle the 14 bolt is a pretty cheap and strong unit.
masonmachines is offline   Reply With Quote
Old 06-26-2003, 12:16 AM   #9 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
While you are correct in stating that the 14 bolt would be a cheap upgrade, the guy said he already has the 12 bolt sitting in his garage.
It doesn't get any cheaper than that.
Now if the 12 bolt needed any serious work, like a new set of gears, or bearings, then I would go find a 14 bolt. Of course that would also require swapping the front axle hubs to an eight lug pattern.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote
