Jeep TJ 2.5L exhaust manifold ?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-07-2003, 09:48 AM   #1 (permalink)
Member # 11588
1997 TJ, 4 cyl. I've got exhaust gas coming out the back of the manifold (near the firewall) that I'm guessing is causing rough idle/accel/emmission problems.
Going to try to tighten the bolts first (when the Heep cools down), but I'm wondering about the condition of the seal at the manifold.
I was thinking it was a gasket problem, but the FSM doesn't
mention an exhaust manifold GASKET. Does it have one?
If so, has anybody changed it w/out removing all the INTAKE stuff?
Never own anything you're not prepared to drill a hole in.
Kilby is offline   Reply With Quote Quick reply to this message
Old 07-07-2003, 05:01 PM   #2 (permalink)
Member # 20512
Send a message via AIM to WhiteKnight87544
If your TJ is like my 97 4.0 Liter, you have one gasket for both your intake and your exhaust manifold. Theres no way to change the gasket without taking them both off.
WhiteKnight87544 is offline   Reply With Quote Quick reply to this message
Old 07-08-2003, 07:27 AM   #3 (permalink)
Member # 11588
Yup... re-reading the FSM (more closely this time ) I see that the intake & exhaust manifold gasket(s) are one & the same.
Old 07-08-2003, 08:25 AM   #4 (permalink)
CoryB's Avatar
Member # 1813
Send a message via AIM to CoryB
Did the rear exhaust manifold mounting stud break off? Common problem on those engines.
There was even an extended warranty from Jeep (up to 80K IIRC) on those - I had it happen to my 98 within the warranty and my 97 about 4K miles after it expired.
No pithy signature here...
CoryB is offline   Reply With Quote Quick reply to this message
Old 05-16-2004, 01:13 PM   #5 (permalink)
Member # 11724
I have a 1997 TJ SE wuth 2.5 engine and it only comes with a gasket on the intake manifold (The exhaust manifold comes without gasket)
Is that OK?
I went to the local mopar dealer here in CHILE, and confirm that again (They donīt sell gasket for the exhaust manifold).
What i have to do with it?
The header just go metal to metal to the engine?
Thanks
Mariano
Santiago, CHILE
UTV Polaris Ranger RZR 2008
mlozano is offline   Reply With Quote Quick reply to this message
Old 05-16-2004, 04:20 PM   #6 (permalink)
jeeplord's Avatar
Member # 28273
mlozano, the intake exhaust manifold gasket will solve your problem
they are one gasket in the same.
[QUOTE=kodiak1232003]"RUN, WHITE PEOPLE!! RUN!..SAVE YOUR FAWKING SELVES!!!" or some sh#t, in broken engrish...."[/QUOTE]
jeeplord is offline   Reply With Quote Quick reply to this message
Old 07-21-2006, 04:18 PM   #7 (permalink)
Member # 17816
I know this is an ancient thread, but it keeps comming up in my yahoo searches for manifold stuff. The 2.5L TJ does not have a gasket for the exhaust manifold, it is mounted metal to metal.
wgjeep is offline   Reply With Quote Quick reply to this message
