shadow tree tuning using O2 sensor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-07-2003, 02:06 PM   #1 (permalink)
Member # 20625
Hi:
Is it a good idea to fit an O2 sensor to the exhaust and take its readings witn an Ohmeter while tuning up the carb?.
Comments are welcome,
jeepinislife is offline   Reply With Quote
Old 07-07-2003, 07:02 PM   #2 (permalink)
Member # 49
It can be done.
Get an O2 sensor that is heated ( 4 wire )
search the web , you can find write-ups on how to do it.
One thing to remember is that they only measure oxygen, not unburned fuel.
All said , I think that for the price they make a good tool for fine tuning.
good luck
Tom
Ok so it's not extreme
but it gets dirty!
The Heartbeat of America Yesterday's Chevy Truck!
Arrow is offline   Reply With Quote
Old 07-07-2003, 07:23 PM   #3 (permalink)
Member # 18989
O2 sensors are like a small battery. The difference between oxygen in the exhaust and oxygen outside the sensor cause it to produce a voltage.
.1 volt is lean
.9 volt is rich
.45 is centerline (about 14.7:1 air/fuel ratio)
They don't produce a voltage unless they are hot, so get a heated one.
Also note that 14.7:1 is a cruise ratio. A computer ignores the O2 sensor during acceleration or deceleration.
A flash of lightning illuminated the object, wretch, hideous, filthy daemon. A new species would bless me as its creator.
frankenfab is offline   Reply With Quote
Old 07-07-2003, 08:00 PM   #4 (permalink)
Damage, Inc.'s Avatar
Member # 20298
Yep...keep in mind they're very much steady-state devices. Which means that data you're seeing happend along time ago (engine-speak).
Damage, Inc. is offline   Reply With Quote
Old 07-08-2003, 10:12 AM   #5 (permalink)
Member # 17366
One thing to keep in mind here is that an O2 sensor is a voltage device, I.E. it puts out a voltage while operating. Hooking a ohmmeter to it will usually blow them up. They do not like voltage applied to their sensor wire.
There are no problems that can not be solved with the proper application of high explosives.
WindRider is offline   Reply With Quote
