Stupid gasket inbetween Tcase and tranny - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-10-2003, 01:39 PM   #1 (permalink)
Pdaddy's Avatar
Member # 8133
Were the hell can I get one? Do they make one or do I need to just sillycone the shit out of it. I replaced my tranny with a rebuilt and its leaked like a mutha ever since. I put a thin film of silicon around it and it didnt seem to do any good. This is a 700R4 to a NP231. It leaks even when sitting for weeks without running its so bad!!!!
LCQ / KOH 09 Co-Driver #62
Midwestwheeler / Hardline Custom
Pdaddy is offline   Reply With Quote
Old 07-10-2003, 02:05 PM   #2 (permalink)
sceep's Avatar
Member # 10798
Send a message via AIM to sceep Send a message via MSN to sceep
Re: Stupid gasket inbetween Tcase and tranny
just make one I find that phone book covers work the best. Or really thin beer boxes, like fosters 12 pack.
lay the "cardboard" on the area that needs a gasket, tap along all edges with a ball-peen hammer to cut the gasket to fit. VIOLA, instant gasket, just add minimal silicone.
Originally Posted by USDA forest service website
It is every American's birthright to use the national forests and grasslands in multiple ways, including outdoor recreation in all its forms.
sceep is online now   Reply With Quote
Old 07-10-2003, 02:19 PM   #3 (permalink)
Pdaddy's Avatar
Member # 8133
Im sure I can come up with some beer box...
If I pull that Tcase off and do that and it doesnt work Im flying to NM to kick you square in the nuts!
Id just rather spend the 1-5 dollars for the right gasket is all.
lazy
Old 07-10-2003, 05:46 PM   #4 (permalink)
CSP
Member # 1533
Not to be a smart ass, but have you tried an auto parts store yet? Kinda hard to tell if one is made based on the info given here.
CSP is offline   Reply With Quote
Old 07-10-2003, 06:09 PM   #5 (permalink)
Member # 16664
Send a message via AIM to pyros46290
if this gasket goes bad, does that let trans fluid go into the transfer case?
pyros46290 is offline   Reply With Quote
Old 07-11-2003, 05:29 AM   #6 (permalink)
Member # 3587
Send a message via AIM to Recurve
I thought the area between the tranny and t-case was dry. If it leaks there then it's the rear tranny seal. Is it different with auto's or 700r4s?
Recurve is offline   Reply With Quote
Old 07-11-2003, 06:22 AM   #7 (permalink)
sceep's Avatar
Member # 10798
lazy
LMAO. well go the the forkin dealer if yer so lazy!. really though, thinest beer box you can find works great, as do phone book covers.
Old 07-11-2003, 12:45 PM   #8 (permalink)
Member # 16664
i would like to know as well
Old 07-12-2003, 11:11 AM   #9 (permalink)
CSP
Member # 1533
There should be a seal where the output shaft of the tranny leaves the internals and a seal where the output shaft engages the tcase. There should be no fluid between them. There still may be a paper gasket between the tranny and tcase mating surface to keep water and other contaminants out, but not to keep fluid in.
Old 07-13-2003, 06:43 PM   #10 (permalink)
Member # 12756
Send a message via AIM to Rokcrler
CSP you got it correct... the output seal on the tranny seals on the input of the t-case... the space is or should be dry...
Rokcrler is offline   Reply With Quote
Old 07-13-2003, 06:51 PM   #11 (permalink)
Member # 19499
Send a message via Yahoo to smbisig Send a message via Skype™ to smbisig
That gasket doesn't exist. The dealer doesn't carry them, the autoparts stores don't carry them.
The were use in the assembly process of the 4x4s. If you really want to put something there just use silcone.
Steven Bisig - Freelance Sports & Commercial Photographer - stevenbisig.com
smbisig is offline   Reply With Quote
Old 07-14-2003, 09:25 PM   #12 (permalink)
Member # 14600
If using silicone to seal, just let the silicone cure before you bolt them together and it won't leak!
Oatmeal is offline   Reply With Quote
