NOOB battery question/wiring - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-01-2003, 09:34 PM   #1 (permalink)
Member # 18501
Send a message via AIM to IHScoutman14
hey, my battery doesn't recharge when its in the scout II. i just rewired it so its not really an IH specific question. the battery was kinda old but it has just started not keepin charge. do you think it is just the battery or my wiring. it just doesn't have enough power to turn it over but can run fine after its been started with the jump.
71 scout II
online crabbing games are where its at
IHScoutman14 is offline   Reply With Quote Quick reply to this message
Old 10-01-2003, 09:45 PM   #2 (permalink)
Member # 15993
Probably just the battery is sacked, check voltage with engine running for about 14 volts and then shut it off and recheck. Voltage should drop, leave meter attached and try cranking it to see what it drops down to. If it drops to 6 or 8 volts your battery is shot. Check terminal connections too though, do this first actually.
molsenmuscle is offline   Reply With Quote Quick reply to this message
Old 10-01-2003, 09:55 PM   #3 (permalink)
3d Artist for Hire!
animator's Avatar
Member # 13701
Send a message via AIM to animator Send a message via Yahoo to animator
Have you checked the water level?
Sometimes I parkerize stuff. PM for info..
animator is offline   Reply With Quote Quick reply to this message
Old 10-01-2003, 10:10 PM   #4 (permalink)
Buddha's Ghost's Avatar
Member # 334
Rewired in what fashion?
Are your terminal clamps on securely and are they nice and clean?
Buddha's Ghost is offline   Reply With Quote Quick reply to this message
Old 10-01-2003, 11:03 PM   #5 (permalink)
Member # 18501
"Rewired in what fashion?
Are your terminal clamps on securely and are they nice and clean?"
yes they are very clean and i rewired with the painless kit for a scout/bronco/landcruiser
"Have you checked the water level?"
yes i have
"Probably just the battery is sacked, check voltage with engine running for about 14 volts and then shut it off and recheck. Voltage should drop, leave meter attached and try cranking it to see what it drops down to. If it drops to 6 or 8 volts your battery is shot. Check terminal connections too though, do this first actually."
yea i'll do that thanks guys
71 scout II
Old 10-02-2003, 12:20 AM   #6 (permalink)
MRfuelish's Avatar
Member # 12376
If it drops to 12.2 volts it is 50% charged!
MRfuelish is offline   Reply With Quote Quick reply to this message
Old 10-02-2003, 03:54 AM   #7 (permalink)
Member # 13880
you might have a short somewhere. Disconect your battery when you go to sleep tonight and reconnect in the morning and see what happens.
84runner with tons,r151,duals with 4.7s in the rear, a little tube and some tenderized sheetmetal.
Rockabilly is offline   Reply With Quote Quick reply to this message
Old 10-02-2003, 08:35 AM   #8 (permalink)
waverider's Avatar
Member # 11971
Did the battery charge before you rewired it?
If everything was working before you re-wired then I would assume that it should work after you wired it.
Which leads me to think that something may not be wired correctly. When troubleshooting always start by looking at the very last modification made.
waverider is offline   Reply With Quote Quick reply to this message
Old 10-02-2003, 01:45 PM   #9 (permalink)
Member # 19089
or mabe the voltage regulater blew..lol
alt puts out enough to run ..
looking for one to build again..
Back in the sac area again!!! glad to be back again!!!!!
mikeswrangler is offline   Reply With Quote Quick reply to this message
Old 10-02-2003, 10:51 PM   #10 (permalink)
Member # 18501
i left the battery on the charger all night and today seemed like it wasn't at full power after the first startup but it didn't die. im just gonna get a new battery anyones cause this ones time is runnin out
71 scout II
