Rear Main Seal - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-27-2003, 12:31 PM   #1 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Rear Main Seal
I have never done one with the motor in the vehicle
Can I change a YJ 6 cyl rear main without pulling the case and tranny?
[CENTER][SIZE="5"][URL="http://www.strong-arms.com"]Strong Arms "Survival Slings" For Sale PM me for a PBB only price[/URL]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote
Old 10-27-2003, 01:00 PM   #2 (permalink)
Member # 23898
http://www.jeepin.com/features/rearmain/index.asp
93 Wrangler 4.0
Leroux is offline   Reply With Quote
Old 10-27-2003, 01:18 PM   #3 (permalink)
biggin's Avatar
Member # 22183
Send a message via AIM to biggin
Its no problem with all of it still in Just remove the rear main bearing cap and take a small punch and tap it aroud the crank till you can get a hold of it on the other side and pull it out. Thread the new one in the same way and replace cap to propper specs.
biggin is offline   Reply With Quote
Old 10-27-2003, 02:15 PM   #4 (permalink)
Member # 5670
not exactly your rig, but i was able to do it in my 97 Ram with v8/auto
http://www.pavementsucks.com/tech/rearmain.php
Nothing to see here, move along
Pavemen is online now   Reply With Quote
Old 10-27-2003, 02:24 PM   #5 (permalink)
Member # 5943
Location: Southeastern MN. (formerly near Chicago, I've ESCAPED!)
Don't use a STEEL punch! Get a brass drift for this so you don't scar any of the sealing surfaces. And be careful of Sneaky Pete tools, the braided steel can still do some damage.
Another tip I've heard is to put a breaker bar on the harmonic balancer nut and gently turn the engine over to spen the seal out. Note that I have not personally tried this......
2 XJs had their rear mains changed in the Slickrock campground in Moab a couple of weeks back. A 4-6 hour job.
ChiXJeff
ChiXJeff is offline   Reply With Quote
Old 10-27-2003, 02:45 PM   #6 (permalink)
Jason R's Avatar
Member # 11598
I know with the 4.0s you can so I imagine the 4banger would be the same.
EDIT: I thought you were talking about your jeep. Yes you can do it w/o pulling everything back.
This space for rent.
Jason R is offline   Reply With Quote
Old 10-27-2003, 03:18 PM   #7 (permalink)
Weasel's Avatar
Member # 5639
best write up I have found one the web:
http://www.darksiderz.co.uk/technica...main/index.htm
might have to register but it's a good site anyways.
Weasel is online now   Reply With Quote
Old 10-27-2003, 04:27 PM   #8 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Hi Keith!
How are ya mon? Hey, there are a bunch of write ups out there, so I suggest read them, since tehre are a bunch of tips on the repalcement of teh main seal.
The one I liek the most is teh one Larousx posted before on:
http://jeepin.com/features/rearmain/index.asp
I recomemnd getting two sets, since those things can fall apart (mine had a hairline crack on teh rubber, so I got another one). Use soap water to isntall them, it makes teh job easier, at least it did for me).
ANother good write ups here:
http://www.bc4x4.com/faqs/yj.cfm?cat=5&faqid=40
http://www.ifsja.org/tech/motors/rearmainseal.shtml
Make sure taht the seal lips face the engine!
Good luck!
Gui
geberhard is offline   Reply With Quote
Old 10-27-2003, 04:53 PM   #9 (permalink)
MC
MC's Avatar
Member # 21997
Send a message via Yahoo to MC
two piece main easy to replace, turning the motor over will NOT take the upper half of the seal out, dont put the seal in backwards (easy to do)
Industrial Quality CNC machines at a Hobby Price!
USA Quality is job #1
We build CNC plasma tables, click me
American Motors Engine HERE!!
1-651-257-7917
MC is offline   Reply With Quote
Old 10-27-2003, 06:21 PM   #10 (permalink)
Member # 19089
hey keith.. so your a noob again..
man thought you knew it all..
lol
hey what do you tell everyone ..
USE THE SEARCH BUTTONUSE THE SEARCH BUTTON
so there.. go find it..
laters..
yea you can do it.. its e-z..
just use a brass punch tho
and I have tried to use the installer wire.. forget it..
just push it in till it gets tight.. turn the shaft to finish it..
make sure its in all the way tho..
use some assy lube for the seal.. when you install it..
if you cant get it.. lol
use a bigger hammer.. on it
later ..
mike
93 wrangler,456 gears,33x12.5 tires,on board air,3" bodylift,4" shackels, front axel open,
rear track lock , daily driver, spring over ... passenger side step ..for wife to get in..
91 4runner stock for now with 32's
mikeswrangler is offline   Reply With Quote
Old 10-28-2003, 10:50 AM   #11 (permalink)
Member # 477
Suck me
Thanks for the links guys
[/SIZE][/CENTER]
Old 10-28-2003, 05:51 PM   #12 (permalink)
JeepinDoug's Avatar
Member # 13028
Keith, You'll need to drop the passeger side motor mount out of the way to drop the pan.
Push one side of the seal and then grab the other and rotate it out.
The trick is installing the new one.
***DO NOT OIL IT***
You could actually put a slight coat of vaseline or assm lube on the seal side only. On the block side of the seal use liquid dish soap to make it slippery.
Oil will swell the rubber making everything tight as h3ll. It's already gonna be tight pushing back around, tight enough to shear rubber off the block side of the seal.
On the cap seal use oil if you want, it doesn't matter.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 10-30-2003, 07:51 AM   #13 (permalink)
Member # 477
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO
Are you sure?
[/SIZE][/CENTER]
Old 10-30-2003, 08:50 AM   #14 (permalink)
Moderator
geberhard's Avatar
Member # 5861
Hmmm, I did not have to drop the motor mount on mine, and the pan came out fine. Doug, do you have a body lift kit or something that moved your engine up? ine was ok, and I had no problems removing the pan. Again, that was on a YJ.
Gui
Old 10-30-2003, 12:43 PM   #15 (permalink)
biggin's Avatar
Member # 22183
***DO NOT OIL IT***
I never removed the motor mount. Hmmm. Are you talking about a 2.5 maybe
Old 10-30-2003, 12:50 PM   #16 (permalink)
Member # 19089
hey kieth..
ok.. heres how to do it..
remove all mounts
remove all fuel lines and other stuff connected to the engine.. including the transmission..
pull out the engine.. replace engine with a 350 chev..
and get adapter for trans.. put it together and there you go.. good as new..
hey
good luck..
its e-z to do realy..
just take your time doing it..
dont let it get you mad..
later
mike
Old 10-30-2003, 05:21 PM   #17 (permalink)
JeepinDoug's Avatar
Member # 13028
Mine's a CJ5 with a 4.2, same configuration. I use a MORE bomb proof mount and had to disconnect the bushing section just enough to let it drop out the way. Remember the pass side has the bulge for the dist and dip stick, it's hard to get the pan past the mount b/c of the ear in the pan.
It's not a big deal to do, just stuff a 2x4 between the alt mount and frame rail.
If you have stock mounts than maybe it's easier to get the pan out, I can't remember, it's been years since I had to fix a stock mount.
Old 10-31-2003, 11:58 AM   #18 (permalink)
Member # 477
hey kieth..
remove all mounts
hey
good luck..
later
mike
Its my brothers mall crawler and its going up for sale
[/SIZE][/CENTER]
