8.8 swap ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-28-2003, 04:12 PM   #1 (permalink)
Member # 15606
8.8 swap ?
I just did an 8.8 swap for my '88YJ and the brake pedal now goes to the floor. I have been told that because of the discs in the rear that the master cyl. needs to be upgraded to handle the added stress. The only trouble is finding one that will match the original mounts and lines. Has anyone had this problem or know what part will work?
Thanks
Neal
'88 YJ, SOA, 8.8 w/Detroit and 4.10's NV3550, and 36's
Neal'88yj is offline   Reply With Quote
Old 10-28-2003, 04:37 PM   #2 (permalink)
Poor White Trash
Norm's Avatar
Member # 4387
It sounds like air in the lines. You don't need to screw with the master cylinder. I pulled the o-ring out of my proportioning valve to give a little more flow to the rear discs. But it worked ok before doing the o-ring trick. If you search you will find some info on how to fix the proportioning valve to give you better rear brakes. But bleed your lines again first.
"My Border Collie is smarter than our president"
Norm is offline   Reply With Quote
Old 10-28-2003, 05:08 PM   #3 (permalink)
Member # 15606
I've bled the lines about 3 times and replaced the master cyl. with another stock one and no go. By any chance did your Yj have ABS because I've been told that this would make a differance.
Old 10-28-2003, 06:14 PM   #4 (permalink)
Member # 4670
Send a message via AIM to GOFER
The calipers will fit on either side make sure the bleeder is on top
Learned this a few years back over one afternoon hehe
GOFER is offline   Reply With Quote
Old 10-28-2003, 09:31 PM   #5 (permalink)
OkLaHoMaYJ's Avatar
Member # 17969
Send a message via AIM to OkLaHoMaYJ
I have a 95 wrangler with ABS a D44 front and F8.8 rear. I have 4 wheel disc brakes and have a stock master cylinder. Everything on my setup works perfect. Had to bleed the system like 5 times to get everything to work right but the pedal is at stock pedal pressure and only goes down like an 1'' further than it did with the D30 and D35c disc/drum combo.
My waggy is an 85 D44 and my 8.8 is a 98 out of an Exploder. I have stock rubber lines in front as well as stock hard line and rubber line the rear 8.8, if mine works....your's should. I can post pics if need be.
2012 F150 FX4 EcoBoost - Wanting a built LJ/JKUR
OkLaHoMaYJ is offline   Reply With Quote
Old 10-29-2003, 07:27 AM   #6 (permalink)
Member # 3893
I was about to say the same thing, I bet that's his problem.
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly...
'06 Dodge CTD 4x4 QuadCab
TornadoTJ is offline   Reply With Quote
Old 10-29-2003, 07:36 AM   #7 (permalink)
MossMan's Avatar
Member # 11995
Send a message via MSN to MossMan Send a message via Yahoo to MossMan
i found out the same thing when I stalled on a very steep hill and mashed the brakes. pedal felt fine but the rear tires did not lock up, just the front. that was a fun slide back down. Anyway, I removed the o-ring in the prop. valve and it's been good ever since.
MossMan is offline   Reply With Quote
Old 10-29-2003, 11:16 AM   #8 (permalink)
Member # 15992
ditto the bleeders on top
i can go everywhere everyone else does -- the new england mantra
kjp98TJ is offline   Reply With Quote
Old 10-29-2003, 01:12 PM   #9 (permalink)
Member # 15606
Ok, so if the bleeder valve is on the bottom it'll cause a lack of pressure?
I'll have to check.
as far as the o-ring in the prop. valve, I'm concerned about the safety factor.
( my brke guy refuses to do it)
mine does not have ABS so that is another reason why it's weak.
So no one knows if an ABS unit will fit my mounts and original lines?
Old 10-29-2003, 06:30 PM   #10 (permalink)
Member # 15606
ok, I checked the bleeder valve thing and yes I had them backwards.
But my brake guy took my master cyl. to find a stronger one that will fit.
My question now is has anyone done this swap who doesn't have ABS and is still using the original master cyl.?
Old 10-29-2003, 06:40 PM   #11 (permalink)
Member # 11535
Send a message via ICQ to Binderfan2002
Thats scary that your break guy dident catch that.
TDO Dysfunctional Rockcrawlers
Binderfan2002 is offline   Reply With Quote
Old 10-29-2003, 07:16 PM   #12 (permalink)
JeepinDoug's Avatar
Member # 13028
First off, when you go from rear drum to rear disc you need to pull the residual valve from the master. The drum brakes keep around 9 psi in the wheel cylinders to keep the cylinders from backing off all the way.
The bleeder needs to be on top so you can bleed it properly, air rises the highest point.
If you install a new master you need to bench bleed it, if you don't you'll be scratching you head for a long time.
You need a master with a rear reservoir that has the capacity to fill the calipers. For a CJ an early 70's Corvette master bolts up to the Jeep booster or firewall. These perticular masters also have a large piston, 1-1/8" for more volume per stroke and a shorter pedal throw.
I may lack much in way of integrety but I make up for it with pure denial.
[URL=http://www.pirate4x4.com/forum/showthread.php?t=377480][B][COLOR="Red"]Malvado Grande #1[/COLOR][/B][/URL]
JeepinDoug is offline   Reply With Quote
Old 10-30-2003, 11:54 AM   #13 (permalink)
Member # 15606
Excellent how about for a YJ?
Old 10-30-2003, 01:44 PM   #14 (permalink)
Member # 15606
OK it works you were right bleeder valves upsidedown.
Old 10-30-2003, 05:32 PM   #15 (permalink)
JeepinDoug's Avatar
Member # 13028
Being the YJ is an 88' it may use the same booster as a late CJ. Take the booster or old master to VatoZone and start pulling different masters to compare with other masters that were used in 4 wheel disc cars, like the Vette.
Old 11-02-2003, 07:56 AM   #16 (permalink)
NothernAZxj's Avatar
Member # 8528
Damn dude find your self another Brake guy, he has to be the worst if he cant find that mistake, or did he install them that way himself?!
Brian Harmon
NothernAZxj is offline   Reply With Quote
