Member # 13707
Do I need a lond travel drive line?
I have 3" allpro's with a 7" eye to eye shackle. I just recieved my shock hoops, so I will have longer shocks. I plan on going to hysteer.
Can I simply have the stock shaft lengthened, or will I have enough travel to need a long travel? 85 toy |
won't know for sure until installed....once all else is done, "hang" the truck from the frame and make sure the axle droops completely. Make sure you have at least a couple inches of spline connecting still.
When I did my SOA lift and raised the truck like that, the driveshaft fell out. Some measurements and I discovered I used a worst case 7" of stroke... EDIT: test the droop without shocks, that way it's a "for sure" worst case.
Brian 'woody' Swearingen - IH8MUD Inc. '74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR |
Member # 940
My first guess is yes but the stock yoda shafts have quite a bit of travel.
WWW.PCRYO.COM Deep Cryogenic Tempering Service Find all my products at www.KICKASSOFFROAD.COM 916-434-6978 Custom Axles built to order. Got 40 spline? I have the hubs, spindles, and axles you need to kickass! Custom Hummer wheels and centers Axle Resplining |
Member # 62
7" shackle sounds awful long, hope you have steel shims under the spring to fix pinion angle. With long travel shocks you are pushing it, with stock mounts I got away with it for awhile but the shocks were short and limited travel.
Jeff Neves |
Member # 13707
How do I measure the total compression? or does it not matter as much because there will be more droop than compression?
with the truck at its static postion I measure 30" from the pinion nut to the nut holding the flange on the t-case. Are the toyota u-joints something that I need to worry about? I have 33"s now, but plan to go to 35's. Are the stock ujoints strong? Last edited by Toyoda; 11-13-2003 at 04:45 PM. |
