Toyota SAS Candidate - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-20-2003, 09:35 PM   #1 (permalink)
Newbie
Member # 23126
I'm planning on a SAS on my Runner and have a chance to get a front axle which currently resides on a 77' Jeep Cherokee.
Can anyone tell me if this would be a good axle for a swap? Of course the carrier and gears will be changed to match my rear which is 4.88 now.
The knuckles are both flat on top. There is no manaul locking hubs. Pass side Pumpkin.
We tried to get a quick measurement on the WMS and it looks like 60".
I have act quickly on this before the vehicle get hauled away next week, so any inpuy will be greatly appreciated.
Mark
akitadog is offline   Reply With Quote
Old 11-20-2003, 10:12 PM   #2 (permalink)
Banned
Wideopen's Avatar
Member # 22380
I'm pretty sure it's a dana 44. They are pretty good axles, It even matches the lug pattern of the rear. I say go for it, Throw some warn hubs on it and add some 4.88's with a locker and run it.....
One problem though, Is the fact that they are SUA, And alot of people dont like flipping the perches on them for some reason??
Wideopen is offline   Reply With Quote
Old 11-21-2003, 12:28 AM   #3 (permalink)
Member # 15729
Search in the yota forum for Bones. I know he did a waggy axle. Erik B's site is a gold mine for dana 44 swap info
http://home.4x4wire.com/erik/
Dirty Harry over on 4x4wire.com did it as well, and has documented in on the site.
http://www.4x4wire.com/toyota/tech/dana44/suspension/
Daniel
"Hatred is the stillborn child of ignorance and boredom"
Laughter is offline   Reply With Quote
Old 11-21-2003, 08:28 AM   #4 (permalink)
Newbie
Member # 23126
What sort of problem does that pose?
Mark
Old 11-21-2003, 08:36 AM   #5 (permalink)
Member # 14496
Send a message via AIM to Violent91
Alright. Its a good axle. If you can get it for cheap, i'd do it. (if not, just get em for the flat tops) I used a 79 axle. It didnt have flat tops and i had to get some. 77s have flat tops so if you want to run a 60" D44, that would be the one to get. To do a spring over....just grind the housing piece on the axle to a flat surface and drill centering holes. Make a perch for the longside tube and shes ready.
The only downside to this axle is you'll need to know that large tires (about 37+) with 3.5"+ backspacing will rub due to the larger spring center. ALso know that with this axle, you'll have to outboard the springs and you wont be able to run 'through frame' shackles.
91 Toyota Pickup 350ci/th350/np205 Open D44 Welded 8"rear on 38s
(PM me if you have a D44 locker for sale)
Violent91 is offline   Reply With Quote
Old 11-21-2003, 08:46 AM   #6 (permalink)
Member # 7938
It is ok but why not go with a Toyota front
KS Toy is offline   Reply With Quote
Old 11-21-2003, 08:59 AM   #7 (permalink)
Member # 14496
I didnt because it takes a long time for me to upgrade. Swapping in an 8" without putting in longs aint worth a crap.(obviously) Only when you get longs can you run the good trails and get bigger tires. I also liked the extra little bit of width that it gave me.
Old 11-21-2003, 10:50 AM   #8 (permalink)
Newbie
Member # 23126
I won't be running anything larger than 33's.
It is ok but why not go with a Toyota front??
I can get this axle for 200 which is alot cheaper than a stock Toy axle.
I can then get it shortened to match the rear and still have a stronger axle without having to in vest alot of money initially.
Mark
Mark
Old 11-21-2003, 11:06 AM   #9 (permalink)
Member # 54
Thank god no one ever tried to wheel a Yota before Long's were invented
Pazuzu is offline   Reply With Quote
Old 11-21-2003, 12:31 PM   #10 (permalink)
Newbie
Member # 23126
Mark
Old 11-21-2003, 12:37 PM   #11 (permalink)
Member # 14496
The d44 is perfect for you then. Go for it. Build a small drop hanger and use the stock 7 leaf waggy springs and hopefully you can stay low enough to run 33s.
Old 11-21-2003, 12:39 PM   #12 (permalink)
Member # 14496
Well you ain't gonna get far in 4wd w/35s and birfs....much less if its locked. Dual case or not.
Old 11-21-2003, 02:32 PM   #13 (permalink)
Member # 7938
This is bs but that is ok if you don't know any better. I don't want to start yet another 44 vs Toy debate. If you want the 44 go for it. If want that 44 to be very strong at all you will have to spend a lot of $$. Ask anyone who has been through this. FWIW Bones has over $2000 in his and that is with some of the parts being used. I am not putting down the 44 but it is all in what you want and how much time and $ you have. Good luck in whatever axle you choose-Brad
Old 11-21-2003, 02:38 PM   #14 (permalink)
Banned
Wideopen's Avatar
Member # 22380
You can wheel the shit out of a toyota front. They live alot longer if they are open, But even if they are locked up, be smart with the skinney peddle, And dont give it full throttle with the tires turned or pinched and you should be good, Especially with 33's
Old 11-21-2003, 03:16 PM   #15 (permalink)
Newbie
Member # 23126
Thanks Brad,
My intention was not to start a debate or something worse.
I was just looking for some info on this axle.
Mark
Mark
Old 11-22-2003, 12:33 AM   #16 (permalink)
Member # 16789
I've seen some narly wheeling with 35" mudders, duals with 4.7's, and limited slips front and rear. This guy I'm referring to has wheeled for years with this set-up, and never broke a birf. How? He let the vehicle do alot of the work, and he realized he didn't need to use the gas peddle to go where he wanted. If you are kind on the vehicle, you won't brake birfs as often as you think.
montezuma is offline   Reply With Quote
