setting my 302 to tdc to get the timing close - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-07-2003, 10:30 AM   #1 (permalink)
synds9's Avatar
Member # 10360
Send a message via AIM to synds9
i redid my intake manifold gaskets and marked the dist and everything put it back together but it seems like it's a tooth off when i go to start it. how do i get it to tdc and get the timing as close as possible?
and i need this truck tommorow for work
synds9 is offline   Reply With Quote
Old 12-07-2003, 10:49 AM   #2 (permalink)
4x4 ADD
noclinkers's Avatar
Member # 23026
TDC.
Take out the no.1 plug and put your finger over the hole ( disconnect the coil) and have someone bump the engine over until the compression pops your finger off the hole. You are now on TDC. No. 1 plug wire goes where the rotor is sitting...Some like the rotor to face the No. 1 hole but, that is personal preferance. Hope this helps, Bob
noclinkers is offline   Reply With Quote
