how much heat can a catylac conv take? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-04-2004, 10:21 PM   #1 (permalink)
Member # 23145
i put in new cats a few moths ago and i had some carb work done...the shop put my wires on wrong and it ran kinda funny,i pulled into th gas station and heard a sizzing sound and when i looked under,my cats were red hot...would this cause them to not do there job? would they give me any signs of being fawked in anyway? the flow feels fine...im asking this because im not passing smog and i was positive they would have helped me....im hopeing the heat didnt mely anything in there....
anything helps....Sean
'94 XJ ,5150s,trussed,aussied D30/narrowed,spooled 33 splined,moser shafted 9",36" TSLs
Foolsize is offline   Reply With Quote
Old 01-04-2004, 11:26 PM   #2 (permalink)
Ford4x4Chik27's Avatar
Member # 23189
Send a message via AIM to Ford4x4Chik27 Send a message via Yahoo to Ford4x4Chik27
Well I guess that goes to show you how much it can take
'93 Isuzu Amigo, yota axles, 35's, blah blah blah
Ford4x4Chik27 is offline   Reply With Quote
Old 01-05-2004, 08:22 AM   #3 (permalink)
Member # 23145
hey hey....well yeh it heated up the outer shell but im asking about te catylac conv itself...its wrapped in aluminum so im assumin that wouldnt be too hard to heat up....anyone?
Sean
Old 01-08-2004, 05:12 PM   #4 (permalink)
THIS SPACE FOR RENT
dane's Avatar
Member # 21948
A friend of mine had a bad o2 sensor in his 91 yj that allowed it to run waayyyyy too rich and the heat killed the cat, it melted the insides, but it ran like shit after that and it sounds like yours is ok. just my .02.
dane
HOOLIGAN
ROCK
CREW
SEE WHAT THE HYPE IS ALL ABOUT:
http://www.facebook.com/hooliganrockcrew
I WILL TRY BEING NICER IF YOU TRY BEING SMARTER.
FU JS FU KS FU RTF FU FOTR FU DA FU RMK
dane is offline   Reply With Quote
Old 01-08-2004, 08:46 PM   #5 (permalink)
mjlogan88's Avatar
Member # 23553
dane
Yup, thats what usually kills them. Maybe lean that thing out a little- running ritch is what killed my brand new cat after a month.
mjlogan88 is offline   Reply With Quote
Old 01-09-2004, 02:55 AM   #6 (permalink)
Member # 20592
Send a message via AIM to gumbojeepyj Send a message via Yahoo to gumbojeepyj
running rich give cooler EGT's unless that extra fuel is actually burning in teh cat then running rich wont hurt it much...
lean mixtures give extrmemly high EGT's and has been know to turn a set of headers bright orange and nearly white... and in fawking glowing!
butif your cats were red , yep they are probably fuct.
Blake
http://www.lockitupoffroad.net
gumbojeepyj is offline   Reply With Quote
Old 01-09-2004, 04:37 AM   #7 (permalink)
Member # 12516
Send a message via Yahoo to Lt1Cj7
I agree with this, If they where that hot on the outside, my bet is it burned the coating off the comb, make the shop replace them!
Lt1Cj7 is offline   Reply With Quote
Old 01-09-2004, 10:24 AM   #8 (permalink)
Member # 2720
if the cat glows it still works. cats don't burn out with heat they burn out when the vehicle runs like shit. crossed plug wires would kill it but depends on how long it ran like that. and runing rich is what would kill it and rock hitting it and speed bumps are the main problem. pm me the numbers it was failing on and all the details and i'll help u out. by the way i own a smog shop in sacramento.
thou shal have cool shit
suzuki w/the HEAT is offline   Reply With Quote
